Help, I am having problems.
Hangee_77
Post by Hangee_77 »
First problem is that my vst Instrument plugins (XTC mode) don't state my MINIMAX & POISON FM Synths, but apparently they do in the Scope mode. I noticed that I don't have the .dll files for those synths in the vstplugins/XTC folder. Is it what caused the problem? Any input?
Second problem is that when I open my Scope platform and roll over my mouse to the 'Manual', the manual is gone. How do you get it back?
Thanks a lot.
Hangee_77
Post by Hangee_77 »
Thanks for the reply,
I am sorry for the first issue, I don't really get your answer, does it mean that I have to reinstall it again?
For the manual issue, I have checked the manual folder & it contains nothing except 3 blank folders (English, French, & something...).
he means you need to open SFP to set your XTC as preference...plus latency and thelike :smile:
Hangee_77
Post by Hangee_77 »
I have already checked the enable xtc mode option in the scope settings but nothing changed.
On the manual issue, may I know what folders/files are inside the 'Manual' folder?
Thanks.
inside the manual folder is a subfolder named after the language you choose to install.
Inside that folder is the top level PDF document SFP-Version-Manual and another folder called Chapters.
Inside Chapters are the PDFs dealing with general stuff and subfolders for... you guessed it - each chapter, as are:
effects, mixing, sampling, studio, synth
no more subfolders at this level, those folders contain the respective PDF docs for each topic.
cheers, tom
ps - the names above are not exact, but a guess from the German version as I deleted english and french for disk estate
Hangee_77
Post by Hangee_77 »
Thanks, the manual is working now.
Regarding the xtc mode issue, does it matter if I have 2 different Creamware cards with different registries? (ex. I have 2 same modules with different registry within 2 creamware cards)
Hangee_77
Post by Hangee_77 »
I did open my normal Scope & load the MINIMAX synth after I finished installing it, it was there but when I go to the xtc mode, no MINIMAX synth available.
