Greetings Experts
please pardon my double post -
http://www.planetz.com/forums/viewtopic ... &0&start=0
intuition tells me I will get more reads in this forum:
my setup: Mac G4 OS9.2.2, SCOPE card, SFP, Digital Performer 2.72, OMS. etc
I have been rasslin with a problem for a few days now where I cannot reliably record with SFP>Sample Rate in SLAVE Mode (for incoming ADAT signal) + have the Sequencer (DP) set to MIDI Slave To Ext. Sync.
What happens is either the MIDI stops working (OMS) and/or the Audio (in thru ADAT input) ceases to stream OUT thru SFP ASIO.
Working this way is very delicate anyway as the Sequencer cannot be launched when SFP is in Audio Slave Mode, and switching from Mater to Slave must be done very carefully once the Seq. is already launched.
I am able to do one or the other (audio or MIDI sync) fairly reliably - and OCCASSIONALLY both(!) - but usually not.
Sometimes what happens is a get a few bars of AUDIO that passes thru ADAT input to ASIO poutout - and then all audio frops, which I assume is ASIO losing sync.
What do you think? I welcome your thoughts!
Thanks in advance
Ed
ADAT Slave + MIDI Ext sync..losing ASIO, losing OMS
- alfonso
Replied something in the original (and more properly placed) thread.
http://www.planetz.com/forums/viewtopic ... t=0#128218
