Doubler
Music Manic
Post by Music Manic »
Want a simple device that will double the signal exactly in phase with an option to move it out of phase by sample.
E.G. I have a drum loop and put DOUBLER as an insert,so it give a slight amplitude lift then I want to be able to phase shift it horizontally.
Would it be possible to get a sample accurate double?
alfonso
Post by alfonso »
Flexor has a sample delay. To double a signal you just have to mix two cables from the same output, if you put a sample delay on one of the two paths you're done.
Music Manic
Ye just looking for something very quick.
Lima
Post by Lima »
You can try this:
http://www.planetz.com/forums/viewtopic ... 5&forum=16
:smile:
<font size=-1>[ This Message was edited by: Lima on 2005-11-06 01:12 ]</font>
