Mixer Bussing Mystery
edmann
Post by edmann »
Greetings
I have a multichannel project that is "ready to mix"...all channels are bussed thru the SCOPE 1632 Mixer - when play from the sequencer everything shows up on appropriate channels on the 1632's meters.
I bussed the 1632's MIX outputs to ASIO channels 11-12...and what I want to do is take that Buss and record the Mix onto (2) new tracks in the Seq.. The New Tracks have ASIO 11-12 selected as Input - but (apparently?) no signal is being sent there, as the nothing records.
Mystified...I am.
Can the 1632's MIX buss be redirected such as I am trying to do?
Anything else stand out that is an obvious problem in this configuration?
Thanks very much in advance -
Ed
Indeed, that's common routing to record the mix... When an active mix output is routed to an AISO Dest in SFP, and that destination is set up as an input on a sequencer track, there's not much left but arming the track and pressing record...
If you open the Mixer and check out the inputs, do the VU's show there? You may want to turn monitoring on for a moment. (for the rest, we don't need any sequencer monitoring, SFP can take care of that;)
Hope this helps!
edmann
Post by edmann »
thanks - yes it is strange...all meters show activity... ASIO output routing to the mixer works OK...MIXER Master output shows activity
so this must be a problem in my Seq (DP) altho I cannot figure it out
all other ASIO seems to be routing fine
anyway - thank for the confirm. Atom, at least I know that this is how it should be done
best
Ed
alfonso
Post by alfonso »
The Mix output, if heard, sends out the signal as you hear it, so it's not a matter of the mixer.
I don't know macs nor DP (I've read you use that), but it's something related to those ASIO channels you are using....
Did you try to record anything else through channels 11-12?
If you experience problems you can always route the Mix out to channels 1-2....now that all the tracks are recorded you don't need to have so many inputs activated right?....
Sorry if I didn't help you specifically, but I have a totally different setup...
:smile:
edmann
Post by edmann »
thanks - I have tried routing to outputs 1 and 2 also - no luck.
I have doen this before - successfuly.
So it is a DP problem or something - no doubt in the end it will turn out to be something simple
I hope
thanks!
Ed
edmann
Post by edmann »
strange thing is that I had no trouble tracking the stuff via:
SPDIF > SCOPE 1632 > ASIO OUTPUT > DP
f@#$%^& weird
computers!
OK
okantah
Post by okantah »
edmann you must check your routing, with the 1632 mixer.
bear in mind that ch1&2 must corresponding to output ch1&2.
in your case ch.11&12 MUST to asio dest. 11&12,period.
cheers
edmann
Post by edmann »
understood Okan - what I mean to say is that just for GP I tried 1+2 also (and 3+4,etc)
I am thinking there must be an ASIO pref somewhere that needs to be trashed
if such a thing exists
safari time - this sys has worked perfectly for almost 2 years
thanks everyone
alfonso
Post by alfonso »
cheers
Any Mixer output can be routed to anything else...you're not speaking of mixer outputs right?
edmann
Post by edmann »
actually at this point I am speaking of everything - Mix Outs as well as Direct Outs
What i want to do is send the Mix Outs to (any) ASIO inputs and then record the mix...
thanks
go ahead. you can route any way you want. one caveat, asio modules and seq midi modules must be in place and have the proper number of channels selected BEFORE opening your sequencer. you cannot change the number of asio channels without restarting/resetting your sequencer.
otherwise, ANY audio output can be routed to ANY asio input.
Shayne White
Post by Shayne White »
Can you feed the mixer mains into a wave dest and record it in, say, Sound Forge? Does that work?
Melodious Synth Radio
http://www.binary-sea.com
edmann
Post by edmann »
well folks - I got it done and thanks for all of your time to contribute helpful ideas.
In the end -
1) user error - I had created a new routing window and inadvertantly created ASIO1 outputs and ASIO2 inputs (I know not very much about ASIO)
2) Upon assigning all ASIO i/o as ASIO1 it works
3) mystery to me how I could track this project thru the same config...but I did.
4) ASIO2 is a subject I must study...as I notice in the SFP manual that ASIO2 allows for punch-in low latency monitoring...and (dread) I think DP in OS9 may not support ASIO2
film at 11 just for reference
thanks again Everyone!
best wishes
Ed
use either asio1 or asio2. they both should work. asio2 allows the transmission of clock, otherwise, they work pretty much the same. you can only use one asio driver at a time.
edmann
Post by edmann »
Hi Gary
"transmission of clock"
MTC? MIDI Beat Clock?
(these) to SFP modules, as in clicked LFOs or something?
thanks man!
edmann
midi clock, i believe.
you'll likely never use the feature.
<font size=-1>[ This Message was edited by: garyb on 2005-11-01 13:08 ]</font>
alfonso
Post by alfonso »
From the Manual:
"With the optional Sync Plate you can route time
code from, for example, an ADAT device
to the MTCtoClk module, and from there
to the Clk input on an ASIO 2 dest
module. This makes possible sampleaccurate
synchronization between
Cubase and the ADAT device."
