installation of scope : "next" does not work !
bill3107
Post by bill3107 »
during the installation of one of my cards on a PC, and although i have imported the allkeys (also tried to put the keys manually...), i cannot use the "next" option that allows you to continue the installation... Weird ! That's the first time that i have such a trouble... Any idea of the reason ? I am sure the keys are ok...
thanks
sandrob
Post by sandrob »
maybe, you must to install drivers manualy first?
bill3107
Post by bill3107 »
the driver of the card is installed, so the card is recognized. But the problem appears when installing scope 4. Although keys are written, it does not allow me to follow the installation cos "next" (close to th import option)is not available (grey instead of yellow as it should be...)
don't remember the cure for this one. i believe it happens most often with the downloaded version. there is a file in the scope folder to delete, maybe someone remembers...you can try the scope.rgy file. a clean install will also fix this....
you can try a search...
<font size=-1>[ This Message was edited by: garyb on 2005-10-28 02:49 ]</font>
Nestor
Post by Nestor »
What you have to do is to download a "fresh" file from your mail, and it will work. It does for me... bezzare, but it does...
