Ableton 5 & Scope XTC
Discuss Scope XTC mode.
Peter Cherry
Post by Peter Cherry »
I am ,,old school Cubase user´´ for a long time, but some days ago I persuaded myself to experience strange looking software called Ableton Live 5 :smile:
After a few days of testing I must say it is cool. Session and Arrangment concept provides the most of Cubase linear style with possibility of groove and live style making music.
In addition, the graphics & screen layout is for the first look strange and cheap, but for ral work is very efficient and effective (little bit ,,Pro Tools Style´´).
Of course I can use all effects and instruments as in Cubase.
Starting Initialization of Ableton is much more faster than Cubase
Only thing I did not find out is how to use XTC effects and instruments in XTC mode ?
Does anybody know and what is your opinion on Ableton ? (I must repeat that for a long time I was defender of Cubase against softwares like Reason, Fruity Loops, Cakewalk, Sonar etc)
Peter
Astral Fridge Magnet
Post by Astral Fridge Magnet »
I use Ableton (on my laptop) and it is a brilliant, fast, easy way to get on with music making. As far as using it with XTC I am no help. I can't even use XTC with Cubase or Logic.
petal
Post by petal »
Check out the forum - there are loads of threads concerning your questions.
To get you started:
http://www.planetz.com/forums/viewtopic ... orum=32&11
Peter Cherry
Now I can load XTC devices in XTC mode into Ableton, but the sound is full of crackles. I tried trick with changing ULLI setting before loading device. But crackles are still.
Can you help me ???
XTC under Cubase worked ok and FYI I have Pulsar I.
petal
Post by petal »
Have you tried this?
from Gonzoft FAQ ;
7. XTC mode does not remember your ULLI settings unless you do the following:
Add the following entry into your /SFP/App/Bin/Cset.ini under item
[XTC-config]:
intBlkSize=x
whereby x is a values out of 64, 128, 256, 512 or 1024 and translates as follows to the card's latency:
64: latency = 3 ms
128: latency = 4 ms
256: latency = 7 ms
512: latency = 13 ms
1024: latency = 25 ms
A wrong latency will still be displayed in the ULLI Settings of the ASIO Control Panel, but you can ignore this.
It is a good idea to refresh the plugin info display after changing ULLI settings.
And maybe it's a good idea to read this thread too - I believe it contains all the info and tricks you need to come up and running.
http://www.planetz.com/forums/viewtopic ... 66&forum=3
Peter Cherry
Of course, I tried trick with intBlkSize. I use Cubase and it works ok, but not in Ableton, where sound from XTC devices is full of crackles...???
petal
Post by petal »
It's working fine here.
Which driver are you using - What does it say in "Audio Devices" in Options/preferences. It says "ASIO SCOPE" here, and the Driver Type is "ASIO".
Peter Cherry
I really use ASIO driver (nor MMX or Direct). Which XTCproject are you using ?
petal
Post by petal »
Just the standard one, which I have edited in order to be able to use the wave-drivers while running in XTC-mode, which means that I have added a module to the project, nothing else.
Peter Cherry
I am using slightly modified project also...but I tried to use different ASIO modules (16,24,32 bit) but still the same result...crackles in the sound....:sad:((
petal
Post by petal »
XTC behaves in mysteries ways, which might be why CW don't support it any more.
The trick where you can make 3rd party-devices available in XTC-mode works here, but not all devices which has been proven to work on other systems.
I can only recommend that you try lots of different settings - I too had crackles in Live at first, but I made them dissappear. It's been a while since I made it work, but I believe the solution had something to do with how the ASIO-driver was loaded, or which setings it was loaded with - make sure that cset-file is configured correctly. I think thats the best advice I can give you.
Maybe if you post a sample of the crackles there might be a CW-ear that knows what is wrong?
Peter Cherry
I don´t really know :sad:( this is my cset.ini
Runpep]
InScreen=1
Language=English
[FileBrowser]
All Files=0
STS-Samples=0
LastPath=s:/Samples/SF2/Bass/
[AudioFormats]
Wav=Wav
[Installer]
Version=3.0
App=SFP
OS=3.1
ProductID=3
[ReferenceResolver]
All files_Paths=C:/Scope/;
Modules/Devices_Paths=C:/Scope/Devices/;
Presets_Paths=C:/Scope/Presets/;
All files_AutoUse=1
Modules/Devices_AutoUse=1
Presets_AutoUse=1
[StaticPath]
Modules=
Modular=C:/Scope/Modular2 Modules/
Projects=C:/Scope/Projects/Examples/
Effects=C:/Scope/Devices/Effects/
Presets=C:/Scope/Presets/
HardwareIOs=C:/Scope/App/Application/IOs/Hardware/
SoftwareIOs=C:/Scope/App/Application/IOs/Software/
Bitmaps=C:/Scope/MRC Skins/
Devices=C:/Scope/Devices/
Samples=C:/Scope/Samples/
[Path]
Projects=C:ScopeAppXTCApp
[APPEARANCE]
ToolTips=1
GridY=5
GridX=5
DragWindows=1
StandardCursor=1
[LOAD]
AlignSurfaces=1
LoadMixer=STM 1632.dev
LoadMixerEnabled=1
LoadDefBoard=0
[AUTOCONNECT]
InstrumentToMixer=1
EffectToMixer=1
AudioSrcToMixer=1
DeviceToMidiSrc=2
[SFP]
Favourites_Minimized=1
Favourites_Size=187
FileBrowser_Minimized=0
FileBrowser_Size=564
Dsp Load_SizeY=106
Dsp Load_SizeX=194
Top_Minimized=0
Top_Size=419
About_Show=0
About_PosX=254
About_PosY=14
ControlRanger_Show=0
ControlRanger_PosX=412
ControlRanger_PosY=291
ControlRanger_TopLevel=2000
SFPBar_PosX=782
SFPBar_PosY=2
SFPBar_SizeX=238
SFPBar_SizeY=518
SFPBar_TopLevel=100000
SFPBar_RestoredSizeY=518
Bottom_Size=88
Bottom_Minimized=0
DSPLoad_Load=0
Dsp Load_Show=0
Dsp Load_PosX=470
Dsp Load_PosY=397
Dsp Load_TopLevel=2000
Registry_Load=0
ModuleRegistry_Show=0
ModuleRegistry_PosX=361
ModuleRegistry_PosY=357
ModuleRegistry_TopLevel=2000
Options_Load=0
Options_Show=0
Options_PosX=359
Options_PosY=376
Options_TopLevel=2000
Resolver_Load=0
ReferenceResolveOptions_Show=0
ReferenceResolveOptions_PosX=302
ReferenceResolveOptions_PosY=104
ReferenceResolveOptions_SizeX=332
ReferenceResolveOptions_SizeY=250
SFPRouting_Show=1
SFPRouting_PosX=-6
SFPRouting_PosY=-3
SFPRouting_SizeX=789
SFPRouting_SizeY=595
SFPRouting_TopLevel=0
FileBrowser_Show=0
FileBrowser_PosX=236
FileBrowser_PosY=0
FileBrowser_SizeX=238
FileBrowser_SizeY=518
FileBrowser_TopLevel=1
Splitter_Size=0
Splitter_Minimized=1
SFPDesktop_PosX=0
SFPDesktop_PosY=0
SFPDesktop_SizeX=1055
SFPDesktop_SizeY=548
SFPDesktop_Maximize=0
PulsarConfigSurface_Show=0
PulsarConfigSurface_PosX=377
PulsarConfigSurface_PosY=451
PulsarConfigSurface_TopLevel=2000
[SEQPATH]
Path2=C:/Program Files/Cubase Plugins
Path1=C:/Program Files/Cubase Plugins
[ASIO]
XTCMode=1
application=C:/Scope/App/XTCApp/XTC.pro
Pluginwrapper1=C:/Scope/App/XTCApp/vstsynthplugin.mdl
Pluginwrapper2=C:/Scope/App/XTCApp/vstplugin.mdl
Pluginwrapper3=C:/Scope/App/XTCApp/vstplugin.mdl
Pluginwrapper4=C:/Scope/App/XTCApp/vsthostplugin.mdl
[XTC-Config]
AddHost=1
[Host]
Scoperev=128
[Host-Config]
Numboards=1
Board0=Host
[hw]
intBlkSize=512
[FILELIST]
Akai-Samples=0
Wave=0
[Scope]
PulsarConfigSurfaceShow=0
PulsarConfigSurfaceY=360
PulsarConfigSurfaceX=511
[RecentFileList]
Entry5=
Entry4=
Entry3=
Entry2=D:/000000/XTCProject.pro
Entry1=c:/scope/app/SFPApp/StartProject.pro
Entry0=C:/Scope/App/XTCApp/XTCProject.pro
<font size=-1>[ This Message was edited by: Peter Cherry on 2005-10-31 11:27 ]</font>
petal
Post by petal »
Hmm, mine are a bit different:
Try this:
[XTC-Config]
AddHost=1
intBlkSize=128
[hw]
intBlkSize=128
Hope it helps!
Peter Cherry
I tried to add one more intblocksize but i had to leave 512 because I have Pulsar I and its minimum latency is 13ms (512).
But still crackles... :sad:((
And also no midi signal from my keyboard in XTC mode (in Cubase everything ok)....
petal
Post by petal »
I'm sorry to say this, but I think the only thing I con think of that I would try now, would be a complete reinstallation of windows, live and Scope following all the tricks and advice from this forum.
But there's still the chance that Live and Pulsar 1 is not working together in XTC-mode.
Has any Pulsar 1 user's XTC up and running in live?
