Hi to all.
Plz somebody can explain me difference of scope default mixers.WIth preorities like:DSP usage,functionality,abilities.
THanx alot.
						mixers difference
As far as features go, they are all pretty well documented in the manual.  Basically there are small tight mixers (Dynamic, Micro), big stereo mixers (STM2448 and 4896), surround mixers, (STM 16S and 48S), and the STM1632 which is in-between the small mixers and the bigger ones feature wise.
DSP-wise, you can assume the more features there are, the more DSP it takes. It's almost impossible to give precise results, since DSP usage will vary based on number of channels, mono/stereo channels, and compressor/EQ stuff you can turn on and off on the bigger mixers.
