Reinstall Questions.
Astral Fridge Magnet
Post by Astral Fridge Magnet »
Hello,
I have reformatted and reinstalling everything from scratch. As it has been a while since I have done this, can you tell me the install order of stuff please?
So do I install Logic and Cubase before Scope 4 or do I install Scope 4 before Logic and Cubase?
Also, if I remember rightly, when I install Scope 4 it asks if I have Scope Home, Project, and Professional. I don't know which one I have.
I have three Pulsar cards. Two with 6 DSPs and 1 with four. How can I find out what the difference is between them?
Finally is it worth installing XTC Mode. I remember trying to use it once before and I got messages saying that it doesn't work while Pulsar is running. Can anyone shed any light on this please? The trouble is that if I don't have Pulsar running, I won't have a soundcard.
Thanks in advance for your responses.
go ahead and install xtc mode, as you have already seen in another post(please don't crosspost) the error message indicates that you have not disable xtc mode (which you should) in the settings window while using scope mode.
install the scope driver, then the sequencer then scope, so that the xtc plugs go in the right folder. if you install scope first, it'll still work fine, just be sure and install the driver before everything. also, be sure that all your system drivers(motherboard and vid card) have been installed before installing programs.
i would just install as professional. any plugins that you don't have keys for won't work, but that's the extent of the troubles. doing that will insure that all the plugins that you own(stock cwa ones, anyway)will be installed.
