Help me, o knowledgable ones, samplerate dissapeared
oaf
Post by oaf »
Hello all,
has anyone encountered a problem like this,
my Samplerate has completely gone, even when any of my card are set as master, and hence nowt makes noise! SFP loads up fine and makes the usual clicks when loading up through my adats, but wont connect to SX 3.1.
It was all running perfectly for months, until i was finally happy with a mix and ready to finish it when the next time i loaded up this happened. i am slighly distrought as this is the closest to completing a tune in about 2 years before hardware failure.
Running a scope pro and 2 pulsar 2 plus's.
Help, :sad:
djmicron
Post by djmicron »
in your setup, you must have just one samplerate master device and all others to slave.
If You set the scope software to master, You must set the adat converters and all digital hardware to slave.
Micron
oaf
Post by oaf »
had it runing for years before now, always with CW as master,adat as slave, never changed a sausage.
boohoo
:sad:
<font size=-1>[ This Message was edited by: oaf on 2005-10-15 07:00 ]</font>
djmicron
Post by djmicron »
have You tryied to set scope to slave and the adat device to master?
Common causes would be incomplete registration, DSP overload on some exotic devices etc, but these are accompanied by a popup message. Are you getting any? Any warnings?
It's normal that SX doesn't find the ASIO drivers, it never does when the DSP's aren't locked to some samplerate.
i hate to say it, but that card may have died. if changing the setting and then changing it back doesn't help, contact cwa.
