I have to tune my native gear for a project.
Most synths work in semitones and I need to get a tuning of 442Hz instead of 440 but I don´t know how to calc this to semitones.
BTW:Are semitones and cent the same?
Can somebody help me, please?
Thank you in advance.
Hz to semitones
- ChrisWerner
blazesboylan
Hi Chris.
Here's a cool little calculator:
http://www.geocities.com/CapeCanaveral/ ... /chc1.html
Leave the "inharmonic" thingamabobber at 0.
There are 100 cents in a semitone. (And 2 semitones in a whole tone. And 12 semitones in an octave. A - B is one whole tone interval, whereas B - C is one semitone interval.)
Hope this helps!
Hope this helps!
- ChrisWerner
Thank you very much, the link helped me.
The exact tool I was looking for.
It´s hard/impossible to tune all synths and samplers to +0.0785 cents, though.
The Waves Sound Shifter works fine on the sum channel and through this on all instruments but can be set to whole numbers only.
EDIT: In the sound shifter you can type in a specific ratio to get very near to your demanded result, hupiee.
Thank you again.
<font size=-1>[ This Message was edited by: ChrisWerner on 2005-10-01 03:18 ]</font>
Thank you again.
blazesboylan
- ChrisWerner
Sure, it´s a DirectX but with the wave shell it becomes remoteable with a newer host sequencer like SX. Then you should be able to setup a midi controller on it.On 2005-10-01 12:42, blazesboylan wrote:
Glad it helped Chris! That Sound Shifter sounds cool, I've never used it... Is it MIDI-controllable by any chance?
As I tried, you can tweak it in realtime without artfacts, cool thing.
blazesboylan
Here is the formula, if you don't need to connect to web to obtain the value.On 2005-10-01 02:29, ChrisWerner wrote:
Code: Select all
Is the absolute value of
(log(freq1)*1200/log(2))-(log(freq2)*1200/log(2))
