STS series do not record
Mr Arkadin
Post by Mr Arkadin »
Well i have STS3000-5000 samplers. i recently uograded to SCOPE 4 and up until now hadn't checked the recording side of the samplers. Came to record something the other day and... nothing: it doesn't go into record. i've tried all models.
i had a problem recording in SFP3.1c too, but i found a workaround for that - using an existing wav, copying it, renaming it, dragging it into the Zone and then recording over that. Seemed to work for some reason. Doesn't work in SCOPE 4.
i'm sure this relates to two things: 1. that i'm using SCOPE 4 and 2. i'm on Mac.
i really, really want to avoid the old reinstall SCOPE 4 advice if i can. Plus in really don't think it will solve anything as this is an old problem on probablt SCOPE's weakest link.
Any STS/Mac users out there who have no problems? Please give me hope.
Cheers,
Mr A
<font size=-1>[ This Message was edited by: Mr Arkadin on 2005-09-30 11:57 ]</font>
alfonso
Post by alfonso »
I never used that sts feature because I'm not confortable with the wave display, I prefer to use Sound Forge to make samples, but if I remember well you must first create an empty file as a part of a keygroup of a new program.
I can't check now the exact procedure but if memory doesn't fail you can't just hit record and go without setting a "destination" element in the device.
djmicron
Post by djmicron »
i don't have a mac,
but i use sts 5000 and it's ok.
T orecord a new file, just add a new keygroup, right click (apple+click on mac?) on keyzone and add a new stereo or mono file at 16/24 or 32 bits.
open the sample editor, connect the input of the sampler and record.
works pretty well here(on pc)...
Mr Arkadin
i'm well versed in the somewhat arcane world of creating keygroups and zones etc. - i worked for years on STS3000 pre-SFP3.1c and SCOPE4. It just seems to get more buggy with every (Mac) update)
