allkeys download
Crickstone
Post by Crickstone »
Anybody know how long it's been since the allkeys download hasn't worked? And will it be up soon..I have the keys but it's in notepad file and the file extension is only .sk and they won't import. Can the file be changed back, is that necessary (my other machine and board was a successful install, this is my project with all the mix and master and synth packages)
you should be able to rename the extension. it will likely work then(the allkeys file is just a text file). otherwise, it's enter them manually(it's pretty easy) or contact Ralf.
Guest
Post by Guest »
you won't be able to download the allkey file as this feature is disabled by CW.
you need to contact ralf (rb@creamware.de) with your SN and request that he sends you the allkey file by email
if you enter the keys manually a scope.rgy is created in your C/ScopeApp/bin
an all key file once imported it becomes a scope.rgy
I gave you hints here on how this works
http://www.planetz.com/forums/viewtopic ... 25&forum=1
<font size=-1>[ This Message was edited by: antar on 2005-09-28 18:34 ]</font>
Crickstone
Thanks guys,
New to all this...
