127 Presets for Biocs (SpaceF)
Preset lists and tools for Scope modules
MaoMusique
Post by MaoMusique »
<a name="planetz-file"></a><a href="http://www.planetz.com/Pulsar/files/pre ... .zip"><img src="/forums/images/file_icon.gif" border="0" alt=" File"> File</a><BR> <a name="planetz-tag"></a>Related To: Biosc (SpaceF)<BR> <a name="planetz-tag"></a>Pulsar Version: Pulsar All Versions Ok<BR> _____________________________________<BR><BR> 127 news Presets (LA02) for Biocs (SpaceF).
Amusez vous bien!!!
Laurent.@+
djmicron
Post by djmicron »
thank you :smile:
p.s. i don't have some of the filters and oscillators used in some of the presets.
Is my biosc version different or do i need some update?
<font size=-1>[ This Message was edited by: djmicron on 2005-09-25 14:07 ]</font>
MaoMusique
djmicron:
I have some modules of betatest, write to me the presets which do not go.
I will correct.
djmicron
Post by djmicron »
Hi Laurent,
the missing devices are:
Synth FX-S.dev
4SYNC-UKPWMM.dev
MoonizerIV-mf.dev
MicroEcho.dev
Voxal-IV-mf.dev
sf-Voxalizer.dev
T Delay II.dev
2SYNC-MM.dev
Thank You
Micron
MaoMusique
Salut!
What is your pack ?
"I will ask Medhi which are the modules by pack. I have all the modules BlackBox."
Laurent.@+
djmicron
Post by djmicron »
i have biosc2 and lbh rack.
MaoMusique
4SYNC-UKPWMM.dev / 2SYNC-MM.dev :
http://s-bonobos.nexenservices.com/Blac ... CSYNCH.htm
Voxal-IV-mf.dev = Voxal IV :
http://s-bonobos.nexenservices.com/Blac ... ERLIST.htm
sf-Voxalizer.dev / MoonizerIV-mf.dev:
Old devices.
T Delay II.dev / MicroEcho.dev /Synth FX-S.dev:
I ask Medhi........Wait ; )
Laurent.@
MaoMusique
Ok, You should have the 2 sync & Voxal IV.
For the other device i ask Medhi...wait ; )
Laurent.@
spacef
Post by spacef »
Hi there,
it looks like laurent has used a lot of BlackBox effects, which are more numerous than the ones in biosc (sf filters for example, which are stereo effects, not satellite filters).
In Biosc, you have absolutely all the osc and filters but some of them were renamed for clarity : the 4 synch osc are MUK and PUK :smile:
Monnizer IV mf is Moonizer IV
and so on.
I will make the old ones (same module, different names) avalaible for Biosc Pack too, for compatibility of preset list between users of different packs.
in general : a few osc/filters in biosc pack are not named the same as in BlackBox. Some filters related to DXD or Echo, and which were located in other directories were put in the main filter directory in Biosc.
This was done to save space on the website, and to make things simpler to Biosc users.
Synth FX S and Tdel II : i can make those available for Biosc pack too, no problem.
Biosc includes a much better delay, so i thought that people would not use other delays except basic ones such as delay-s or pattern delay (from CW). Also, some users like to use Masterverb or other modules, not available from spacef, but i can't do anything to help you in this regard (they are available from CW or other third parties).
Sorry about this, I didn't really thought about preset exchange between BlackBox and Biosc Pack users....
It is not an issue of missing modules, but different names for making things more rational in Biosc.
I would also advise tester to update their lists of osc filters and to get rid of old beta stuff :smile:
so in one or two days i should be fine : some osc will be doubled (4 synchs and MUK/PUK for ex, or Synch M/ replaced by the MM in particular).
It is most often just one letter that has changed in the biosc version (some synch had 1 M werehas there should be two, for corespondance with what is actually written on the oscillator).
in the meantime, you could just load the osc or filter with the closest name (as they are all available anyway in Biosc pack).
<font size=-1>[ This Message was edited by: spacef on 2005-09-26 04:14 ]</font>
spacef
Post by spacef »
I have uploaded a zip file with the osc/filters with different names as they appeared in BlackBox/Silverdisc. There are also additional files such as voxalizer, various stereo filter effects (sf voxalizers and a few ohers) and delays (delays are given for the sake of preset compatibility, but are not really supported in BiOsc for quality reason. for example, you may have to set the ulli setting manually in those delays).
There is also an update for the modular hosts as some users told me they had problems with sub presets. it was checked and verified, and uploaded as a seperate download, but they are also in the main biosc pack download now.
Additional modules for laurent's preset list is optional and is a seperate download. If other satellites are not available it means they are beta or old satellites not supported anymore for a long time now. in general, it just a letter or two that has changed. but this is unlikely to happen, most of the modules listed above are now available.
if there is enough interest, i will take more web space and make everything available, but this is not possible right now.
cheers
mehdi
nb : biosc/lbh area is now available from http://www.spacef.com "user area" link in the menu.
<font size=-1>[ This Message was edited by: spacef on 2005-09-28 07:01 ]</font>
spacef
Post by spacef »
nb : laurent list is excellent :smile:
thanks !
djmicron
Post by djmicron »
Thank You very much :grin:
