nuendo midi delay
ARCADIOS
Post by ARCADIOS »
midi notes are played on time but are recorded with a small delay.
the worse thing is that the delay is not specific.
sometimes 1/16, some times half a meter, and some other times no delay, byt only for a few seconds and then it appears again.
I have tried many different settings but no result.
i disabled dx accelleration and no result.
I think i am going to leave steinberg, or even pc's............. "apple" :roll:
<font size=-1>[ This Message was edited by: ARCADIOS on 2005-09-06 08:54 ]</font>
<font size=-1>[ This Message was edited by: ARCADIOS on 2005-09-06 08:55 ]</font>
don't use the emulated ports. did you do this?:
http://pinnacle.custhelp.com/cgi-bin/pi ... _topview=1
if your pc doesn't work right, please don't blame the machine, but rather the setup of it.
<font size=-1>[ This Message was edited by: garyb on 2005-09-06 12:37 ]</font>
ARCADIOS
Post by ARCADIOS »
i have the choice of emulated and non-emulated ports. i have moved the ignoreportfilter file one folder up long ago. Something else happens to my system, unless i am wrong again with my configuration. midi was perfect with emulated port. after much time of playing, the midi was recording just perfectly as if i was klicking with the mouse button the vertical piano on the left. The midi notes were not recorded shifted right, there were drawed just out from the recording line! Am i missing something with emulated port on use?
read about the emulated ports... DO NOT use them.... :grin:
ARCADIOS
Post by ARCADIOS »
at the time my system works perfectly without moving the file ignorepotfilter from its folder.
windows midi does not show anything.
direct music shows the emulated midi
and i have emulated midi only.
but it works perfectly.
non-emulated is always but always wrong in timing, giving worse timings as minutes pass.
"pinacle casthelp" says about some specific interfaces that cannot handle emulated ports.
i am not expert. i just see that it works.
i am looking forward to try a better solution. if there is.
abit ic7g
prescott 3.0
scope pulsar2+scope pro
asus ati ax800pro
2g ram
ichr5 with 2 raptors
xp sp1
yamaha clavinova midi out.
o.k.
well, use what works.
