Cannot install SFP Software!!!!!!
Timbini
Post by Timbini »
after formatting harddrive and installing
winxp home, i cannot install sfp software
4.0 or 3.1.
Pulsar 2plus Driver is installed properly.
No error message in device manager.
When i start software installation there is a message:
Hardware cannot be setup properly
installation error:Pulsar2 SRAMTest failed
data 0x00002000 reads 0x00000000.
Please check hardware for conflicts.
Cannot start creamware installer
(error code 0004)
Many thanks!
jea
Post by jea »
you might take your card out of the pc, use an airduster to blow away dirt & dust, clean the pci-contacts, and the stdm contacts using pure alcohol (isopropanol), reseat the card into the pc, then try to install again.
If you get the same error, you might probably have a hardwarefault on the card.
Call your dealer or contact the creamwaresupport for help then.
Hope this helps.
eh, you're right, :smile: I am a luna(t)ech!
<font size=-1>[ This Message was edited by: jea on 2005-09-04 09:52 ]</font>
