loading a project
tim flavio
Post by tim flavio »
hi.i have a problem when i am loading a project cause at the end of loading a message box appear-"there is a problem with sfp.exe application and it will be closed", and then scope is closed.I have been trying to open backup copies but they are also does not working.what is going on???can somebody help me?please....
ARCADIOS
Post by ARCADIOS »
Hello,
what pc do you have?
What os?
How many programs installed?
tim flavio
windows xp professional.Pentium 4 2,4Ghz,1024 ram.how many programs?hmmm...since I have internet access they are growing...but not so much.strange is that sometimes the session can be load normally, but usually it can not:(I have this problem a just few days.earlier everything was ok.help me please...
samplaire
Post by samplaire »
Hi tim,
Welcome aboard :smile:
{Polish}
Czy upgradowales ostatnio komputer? Moze sie przegrzewa? Sprobuj wyjac i wlozyc karte jeszcze raz, a jesli masz ich wiecej - sprobuj poruszac kablem STDM. Moze tez cos sie stalo z RAMem? Jak dawno instalowales system? Sprobuj zainstalowac windows na nowo. Ale to w ostatecznosci.
Aha, czy masz podlaczony do karty jakis sprzet z cyfrowym i/o? Sprawdz czy ten felernuy projekt nie jest przypadkiem ustawiony na slave do tego urzadzenia w ustawieniach "samplerate"...
{English}
Have you upgraded your machine lately? Perhaps it's overheated? Try to reseat your card or if you have more thab one card - try to reseat the STDM cable. How old is your windows install? Try to install it from scratch.
OR, is anything digital connected to your card? Investigate if the problem project is synced to your card (MASTER) or to the outboard gear (SLAVE) in the "samplerate" settings.
Image Sir samplaire scopernicus
<font size=-1>[ This Message was edited by: samplaire on 2005-08-15 04:14 ]</font>
emzee
Post by emzee »
Running anti-virus? Could also just try doing a re-install of SFP over the top.
Keep swimming.....
<font size=-1>[ This Message was edited by: emzee on 2005-08-14 22:45 ]</font>
ARCADIOS
Post by ARCADIOS »
since one year ago after having my pulsar2 and recently my scope pro, i have tried many configurations. i have formated and installed a fresh system over 100 times, with many combinations of partitions and other stuf.
I think that if you want to have a stable system you must have your pc basically configured for audio.
No antivirus, no internet, no games, no small programs without importance.
Just xp, drivers and then scope.
After you may install a sequencer, and finally another one two or three! music machines to play.
I think bigger guys here will agree.
install seperatelly (have 2 xp instalations) in another hd or even controller, for games and internet.
I use southbridge controller with two discs in raid0 for scope and audio generally, and sillicon (my motherboard has two controllers) controller with a hd for fun, internet, games, and scope (but for tests and experiments).
Raid0 is not necessary.
if you want another more simple solution, just use the one controller(maybe you dont have socond) and install in two discs.
one os for audio etc... and one os for internet etc... :wink:
On 2005-08-14 13:45, tim flavio wrote:
... but usually it can not:(I have this problem a just few days.earlier everything was ok.help me please...
what exactly did you do those few days ago ?
did you install/try out any software, hardware, did you update something, etc ?
ther IS a reason for what changed, even if it may not be obvious immediately... :wink:
(for example I once got strange error messages which suggested a re-install would be required, but it turned out that a Ram module I had added just recently was bad)
is this the only project that stucks on load or does it happen with every project ?
cheers, tom
