Audio prob with my 120GB HD
firubbi
Post by firubbi »
hello all,
i cant use my (secondary slave) 120GB hd for audio rec or store samples. problem is audio Crackles. but other 2 hd works fine.
couldn't figure it out for long.
Is it all hd>80gb don't perform well for audio?
my setup:
Mobo- Asus P4T
All HD are seagate 7200rpm
P.master-40gb
P.slave-80gb
S.master-dvdrw
S.slave-120gb
thanks
S.master-dvdrw
S.slave-120gb
Bit of a hint there.
1. are you a accessing the Dvdrw at the same time (samplecd's etc)
2. do you have the Intel accellerator drivers installed or appropriate drivers for your chipset if non-intel?
3. Is DMA enabled for the dvdrw?
At the very least I would put the 120Gb drive as master, and accessing the dvdrw at the same time as using the 120gb drive for audio tasks is probably a no go regardless of drivers.
<font size=-1>[ This Message was edited by: valis on 2005-08-06 09:23 ]</font>
put the c drive and the dvd on the primary channel. put the two data hds on the secondary. be sure dma is enabled.
firubbi
Post by firubbi »
Thanks valis, garyb.
i'll check both.
@valis i don't put anything on dvdrw while rec ** its intel 850 chipset but what is Intel accellerator drivers? ** will check dma of dvdrw.
@garyb ill check as you said.
thanks for your time :smile:
for that chipset with xp, you only need the standard inf drivers from the install disk or, better yet, the latest version available on the intel website. the iaa is only for raid now(unlike with '98).
firubbi
Post by firubbi »
i'd download iaa23_enu from intel site as you told At0m. getting worried to install :???: grayb,at0m its not gonna crash my HD or something... right?
no, it shouldn't do that, but just download the latest inf chipset installation utility from the asus site or directly from intel...
the iaa is for raid only in xp.
did you switch the order of your disks so that the cd/dvd drive is pri slave and the other two data hds are secondary slave and master?
firubbi
Post by firubbi »
http://support.asus.com/download/downlo ... uage=en-us
my mobo is P4T 423 socket and intel 850 chipset.garyb is this should be the right page? what should i downlaod and install form here.
thanks a lot:)
yes. download intel chipset installation utility so:
Version 5.0.2.1003 2003/10/20update
OS Win98SE / WinME / Win2K / WinXP
Intel(R) Chipset Software Installation Utility V5.02.1003.
here's the address:
http://dlsvr01.asus.com/pub/ASUS/misc/u ... 021003.zip
<font size=-1>[ This Message was edited by: garyb on 2005-08-19 04:21 ]</font>
firubbi
Post by firubbi »
Thanks garyb :smile:
thanks again garyb, at0m, valis.
<font size=-1>[ This Message was edited by: firubbi on 2005-08-19 06:59 ]</font>
:grin:
