GPO - Kontakt Player Issue
mausmuso
Post by mausmuso »
Hi There,
Is anyone using GPO with their Scope cards?
I cannot get the stand alone player to work with SCOPE ASIO. It just closes down. It works OK on the directx driver, but I would much prefer the ASIO driver tolimit latency.
I am running creamware 4.0 with a Scope and a Pulsar 2 cards on Win XP SP2.
regards,
mausmuso
Lima
Post by Lima »
I've also have problems with the asio and the NI samplers. I've find a procedure that permits to run Kompakt in my system using the Asio drivers. I hope it can be useful for you also:
http://www.planetz.com/forums/viewtopic ... 10&forum=1
:smile:
mausmuso
Post by mausmuso »
Thanks Lima,
I just downloaded the update for the Kontakt player and its fixed.
I can run it stand alone using ASIO2 24Bit at 48K, which is where I wanted to go.
Should have look for the update first!
I know, I know!!
mausmuso
