spEQtrum - new device and new bundle options
<p align="center"> </p><p align="center"><font color="#FFFFFF"><strong>sp</strong></font><strong><font color="#0000FF">EQ</font><font color="#FFFFFF">trum</font></strong></p><p align="center">An eight band EQ with graphical interaction, four different flavours of filters,<br>zoom, gain-bandwidth coupling, frequency linking and a <br>48 band realtime spectrum analyzer right behind the eq curve.</p><p align="center">spEQtrum is the successor of the 8BandEQ, therefor presets are exchangeable.</p><p align="center">The upgrade from 8BandEQ is available for 20,- €, the full version costs 69,- € </p><p align="center">There are also <font color="#FFFFFF">new bundle options</font> available, where you can save more than 140,- € !!</p><p align="center">Have a look <a href="http://www.worldless.com/sfp/shop.html" target="_blank">here</a> for an overview !</p><p align="center"> </p><script language="JavaScript">function klein(bild){newWin = window.open("http://www.worldless.com/sfp/bild.html?" + bild, "fenstername", "scrollbars=0,toolbar=0,location=0,directories=0,status=0,resizable=0,width=1120,height=350");}</script></p><p align="center"><a href="javascript:klein('spEQtrum_full.jpg')"><img src="http://www.worldless.com/sfp/images/spEQtrum_small.jpg" width="513" height="154" border="0"></a><font size="1"><br></font><font size="1" face="Arial, Helvetica, sans-serif">(click on the pic to view original size)</font></p><table width="513" border="0" align="center"><tr><td><ul><li><font size="2" face="Arial, Helvetica, sans-serif">48 band realtime spectrum analyzer right behind the eq curve, nice e.g for fast room response checking, high/low resolution mode with different dsp usage</font></li><li><font size="2" face="Arial, Helvetica, sans-serif"> fully customizable bandwidth to gain dependancy setting for shelf and parametric filters for each band to e.g. mimic lots of (vintage) eq behaviours out there</font></li><li><font size="2" face="Arial, Helvetica, sans-serif">flexible frequency linking lets you move a cluster of bands and create a completely custom filter out of several bands</font></li><li><font size="2" face="Arial, Helvetica, sans-serif">zoom into the eq curve in 1dB steps (2dB steps for the 24dB amplification) from +/-1dB range up to +/-48dB (or +/-96dB for the 24dB amplification)</font></li><li><font size="2" face="Arial, Helvetica, sans-serif">local preset lists for frequency linking and gain-bandwidth coupling with lots of factory presets</font></li><li><font face="Arial, Helvetica, sans-serif"><font face="Arial, Helvetica, sans-serif"><font size="2">presets exchangable between spEQtrum and 8BandEQ</font></font></font></li><li><font face="Arial, Helvetica, sans-serif"><font face="Arial, Helvetica, sans-serif"><font size="2">same preset list for mono and stereo version</font></font></font></li><li><font size="2" face="Arial, Helvetica, sans-serif">contains all features of the <a href="http://www.worldless.com/sfp/eq.html" target="_blank">8BandEQ</a> and the 8BandEQ itself as well</font></li></ul></td></tr></table><p align="center">For deeper info download the <a href="http://www.worldless.mine.nu/cgi-bin/dl ... EQtrum.pdf" target="_blank">manual</a> and / or visit the <a href="http://www.worldless.com/sfp/eq2.html">info site</a></p><p align="center">If you want a demo, please send a mail to wolfgang (at) worldless.com</p><p align="center"> </p>
spEQtrum is updated now to v1.1 (the update is free for existing customers and the device package price won't raise ! ).
There are three new devices added to the package:
spEQtrum L :
- display of the freq. spectrum of in- and output at the same time
- has a reset button
- background can be made darker in spectrum mode to have better contrast
- frequency grid can be hidden in spectrum mode to achieve better overview
spECtrum M/S (note the "c") :
- just the analyzer part of spEQtrum
- available in mono and stereo
kind regards
Wolfgang
spEQtrum L :
kind regards
Wolfgang
- cannonball
ScofieldKid
Herr Voigt
l'esplosivo
hi guys,
just a short note for my customers:
put the gain-quality dependance to your desired setting and you'll have your pultec or whatever eq right on your finger tips.
.. and a question:
should I deliver such settings beside the fact that you can emulate nearly any eq out there with speqtrum ?
keep in mind that there's a copyright issue .. that's why I hesitated to do so (the settings are already part of the device, they just had to be renamed).
.. and a question:
hi guys,
.. and a question:
.. and a question:
- next to nothing
Music Manic
thanks for all the answers
I'll do some research (forgot which presets are already emulations ..) and will update the preset list accordingly.
MusicManic:
Well, one could fill several books with a still incomplete answer about behaviour differences, but there are two basic things in analog eqs: 1st the in/out stage, which was usually realized with transformers. Depending on the quality of these transformers, the audio signal will be more or less "grinded". You could emulate that with a special frequency dependant fast envelope follower. This is not implemented in spEQtrum as the influence itself is quite esoteric (most discussions about that point as well
The 2nd thing is the circuit itself. This is a little bit explained in the manual (changing bandwidth while boosting/reducing a band in early analog eqs against the implementation of constant bandwidth in analog and digital eqs starting around the 80ies). I could go deeper into the separate components, but in the end the gain-bandwidth relation is the main difference between the several eqs. In spEQtrum any band can have his separate gain-bandwidth dependancy setting to mimic these different behaviours. Additionally the bands might have a dip somewhere in their characteristics. This can be emulated in spEQtrum by linking two or more bands together resulting in a custom build filter cluster.
best
Wolfgang
MusicManic:
best
Wolfgang
As usual I love all 3rd party offerings. I wish there were other businesses in the world that could produce the quality of life like Scope and 3rd party guys have done 4 me, and at such a meagher price. Most of your Pro Tool plugs start at 500 USD. So our platform is the " Poor Mans Pro Tools " around the jingle houses here in Las Vegas. There is nothing poor about it. I call it the " Smart Mans Pro Tools."
Thanks 4 Your Sucsess In Developement,
Music Manic
I'm seriously interested to Wolf's SpEQtrum but I find his interface less intuitive and ergonomic than other counterparts.
In example, I own a couple of UAD-1 and I'm actually without a good versatile EQ like "Cambridge" or Sonalksis "SV-517 Stereo EQ". I find Wolf's spEQtrum very actractive for the features (and obviously the sound!) but I'm in trouble because I like more i.e. this interface layout:
http://my.uaudio.com/store/popup_image.php?pID=28'
http://www.jrrshop.com/images/sonalksissv517.gif
http://www.ursplugins.com/URSS-MIX.jpg
The spEQtrum is too large, the graphic section too "invadent" compared to the knobs section (more important to me!)
Yes, I know that the spectrum feature is rilevant in the dimensional choice. Maybe could be useful a version without spectrum, only EQ with the hi-end spEQtrum sound and setting features. (8 band stereo eq is not exactly the same of spEqtrum)
I think that a redesign could put spEQtrum above the rest of contender.
Some people ends to prefer specific things like Neve or API EQ because the easy and quick usage. spEQtrum is often cheaper and more powerful than many others products but (I've tried a lot of times in a year the spEQtrum demo) I cannot find it ergonomic.
Sorry for my "strange" interface point of view (over the sound quality) but I'm a Graphic Designer
I cannot decide, in these days, to buy an serious EQ between: UAD, Sonalksis, spEQtrum or URS.
I'm tempted from Digitalaudiosoft's EQs but I really don't need another "specific" EQ (I own the UAD's Pultec, wow!)
Now I NEED a powerful & universal EQ like spEQtrum.
Wolf, do you think that it's a hard work to redesign the interface?
Or just redraw the knob section bigger with bigger handy knobs.
Or feature the possibility to switch off the graphic section for a serious space saving (I wish use it XTC mode). Thanks.
Sorry for my bad english. Is hard to explain ideas in different language...
I hope that my comment could help Wolf for a better diffusion of your amazing product.
Scope 4.5 + 2xPulsar II + 1xLunaII + 1xPulsar1 + a lot of devices = Pure Joy
<font size=-1>[ This Message was edited by: erminardi on 2006-06-12 09:35 ]</font>
Music Manic, in fact I only have a pdf-manual for spEQtrum, where the mentioned stuff is written. I'm not writing a book
get it <a href="http://www.worldless.mine.nu/cgi-bin/dl ... f">here</a>.
But after the drag&drop installation it should also be found in your scope directory in the manuals folder or directly available via the LiveBar.
best
Wolfgang
<font size=-1>[ This Message was edited by: wolf on 2006-06-12 12:38 ]</font>
best
Wolfgang
