does anybody know a way (cheap) to reduce the noise and loudness . ? like panels or sound absorbing materials I can use to put on the walls.. ?
I have 2 monitor mackie hr824 facing the outer wall, and behind them there is the wall that goes in his bedroom.
However I know the problem are the vibration from the bass
how can i reduce that ?
please help , I cant express myself.
<font size=-1>[ This Message was edited by: maurizior on 2005-06-19 21:32 ]</font>
My neighbor just came to complain about the loud music
first of all: try to work it out together with your neighbour - people tend to fall into dogs-defending-territory behaviour when it comes to such problems...
analyze the main sources of transmission:
room resonance
wall material and wall resonance, possibly including floor
usually it's good to acoustically decouple the monitor from it's stand.
Since pure mass is one of the remedies I'd use 2 heavy plates of stone with rubber or foam between them - cheap stuff from the home construction market.
for the room resonance you'd need so-called bass traps tuned to your room's resonances (if there are any - but very likely for small rooms).
For a rough check do a low frequency sweep and try to detect peaks by ear. Mind non-linearity of the ear's frequency response at low volumes it's less sensible to bass.
room resonance
Stopping sound is expensive.
If I read this right you are in an apartment. There is nothing you can do that the landlord would find acceptable. To stop the sound requires building a new wall and "floating" the floor...anything else you do is not going to make a difference, especially to the low frequencies.
The advice to move is the best. That and/or buying some headphones.
Or negotiating a time that your neighbor is not home...
R
R
