Logic 5.1+midiportproblem
Timbini
Post by Timbini »
Hi there,
when i start logic 5.1 there is a message: cannot open midiport "creamware midi in/out2" in function "midi in open".
"No driver installed on your system".
I used sfp 4.0 and 3.1a with pulsar2 plus
on winxppro and winxphome with the startup project.There is also no audiosignal from logic in the pulsarmixer.
Many thanks!
this message has nothing to do with your lack of sound. it has to do with the number of midi ports that are listed in the properties section of the device manager and how many module are in your project. you can ignore it or change your settings/project.
more info is required to figure out why there is no sound. do you have asio modules in your project BEFORE opening logic? is logic's audio driver set to asio scope?
Timbini
Post by Timbini »
thanks for your reply,
yes asio modules are in the project , and logic's audio driver is set to asio scope.
There is no midi sound too.
Thank you
Midi sound?
For starters add another MIDI Sequencer source/dest pair to your default project and you won't get the Logic midi error anymore.
As for the lack of sound from logic, can you screenshot the project in question?
