Case fan direction
- next to nothing
Thanks for reply.
I'm gonna place the fan on rear panel;
my case haven't front fan seats; maybe with mini fans in a optical disk seat I could add front fans.
I use a power supply fan with just 2 wires (no rotation control) so I'll connect it to a 12V HDD power plug with a male plug I've scraped up from an old PC; I've soldered wires in the plug; no electric risks for the hardware.
I hope the air flow be correct.
<font size=-1>[ This Message was edited by: Cochise on 2005-06-08 06:35 ]</font>
Lafayette DT-21 multimeter
Pc probe software give me now this values:
Cpu temperature 46°C
Motherboard temp 38°C
I've set it in recording mode and along a cople of hours of work the values are always around those
<font size=-1>[ This Message was edited by: Cochise on 2005-06-11 15:48 ]</font>
The presure ballance is wrong and inefficient if you have sucking and blowing fans...I studied this heaps.
IBM and INTELL have whitepapers on this and other fan companies etc.
Use all sucking or all blowing...sucking prolly better as ps will suck.
Two sucking fans wil pass more air than 1 sucking and 1 blowing..in fact in some situation 1 sucking and 1 blowing can pass less air than just 1 fan.
Usually holes in front lower down and fans at back higher up is best.
Make sure area of air hole comming into the box is exactly same area as going out.
Block all silly other drilled holes in case.
direct air inside with stuff so it flows over the correct places.
Maak
<font size=-1>[ This Message was edited by: maakbow on 2005-06-12 01:58 ]</font>
Maak
Thank you very much, guys.
I was in the apposition to think about ice bags for my pc on August
just kidding
It seems no bad, but I'll watch temperature, for a while.
Quitness is another point sholdn't be not underrated
Just light tasks.On 2005-06-12 03:29, stardust wrote:
yout PC probe values are good if your idle or low loaded. They are excellent under real high load conditions like 3d gaming.
I would not sacrifice quietness for spec values
I have my fan completely in the other room and have barely any noise (just moving air). All I did was take a 4" laundry dryer ducting with a fan attached (pulling air) and connected the other end to the computer case at the top. The fan end is located in the next room. I realize that this isnt for everybody (I drilled a hole in my wall to pass the ducting through) but if you can do it and want maybe 5% noise from a regular setup I would suggest it. Very ideal for a recording situation with open mics.
Running PC probe during a benchmark session I can read peaks til 63°c for CPU, while MB temperature gradually raises till 39° after 30 min of work.
Don't you think the best overclock way is disabling CPU temperature management in the BIOS?
Maybe just a bit dangerous...
Also, try and get your combined airflow in (I think CFM is the measurement that fan and Power Supply folks spec with) and your airflow out are as matched as you can. So if you have (pulling # from my ...) 60CFM from your intake fan, you should try and get as close to 60 CFM out as you can, including your power supply fan in the outtake figure.
You'll always get a little bit of drag against cables and PCI cards, but if they are too mismatched, you may just circulate hot air internally, or not get certain cards and parts to benefit from the breeze.
Sam
Sam
In the hope this can be usefull for anyone else.
I've found solution by this free utility
ThrottleWatch (www.panopsys.com).
It shows CPU work freq and Thermal Throttling activity in real time.
