stm 2448 EQ
cream
Post by cream »
So I just discovered the multiple eq's in the stm 2448 (shame, shame)I overlooked at it the whole time! It's a pity but it's also a pity that they don't work.
Seems like a bug to me again.:sad:
cream
Post by cream »
aha a bug indeed. going to make that 48 db high pass filter work.:wink:
voidar
Post by voidar »
Having used STM2448 extensively I can't say I have experienced this at all.
alfonso
Post by alfonso »
I use it all the time without problems...
Ricardo
Post by Ricardo »
Me too :smile:
R
idem
yup.
cream
Post by cream »
If I select another filter than peak and don't set the 'red dot' in the graphic window I get a 'nill blabla'error. If I first set the red dot and then the filter it works ok..
now I remember...may be there is a little bug, but the trick is, select again the already selected channel, to get the 'right' channel inserts in the mixer's master section.
You won't see happen anything, but after that the inserts work properly.
I noticed that I saw the choosen insert appear in another channel's insert, this happened more than once.
Reselecting the right track solved the 'bug', with me at least :smile:
cream
Post by cream »
Are we talking about the same thing?
I use the stm 2448 EQ, not the PEQ4 insert EQ.(the PEQ4 eq has less types of EQ than the mixer's.
sorry, it was late then, but we were talking about the same thing, cut the insert thing :smile:
