VINCO
titodave
Post by titodave »
What parameters do you use on VINCO with a voice or a mix?
i´m using a focusrite comp but i want to use only the vinco, sell the focus and buy more DPS´s . i´m a sfp addict.
Thanks a lot and sorry another time for my english!
wayne
Post by wayne »
Alfonso's presets are a good start :smile:
titodave
Post by titodave »
thanks a lot
very usefull!!!
firubbi
Post by firubbi »
Thanks alfonso,
its not possiable to insert Vinco. is there any reason behind this?
thanks
voidar
Post by voidar »
On 2005-06-03 02:41, firubbi wrote:
Thanks alfonso,
thanks
Have you unlocked it, do you have it installed?
titodave
Post by titodave »
I can insert vinco in every channel but not the masterverb...
voidar
Post by voidar »
Keep in mind that masterverg, or the verbs in general, only come in stereo, while vinco comes in both a mono and stereo version. Perhaps this is your problem.
firubbi
Post by firubbi »
Yes i'd install Mix n Master Pack where i got vinco. but not available at insert. do i have to do any change of setup?
thanks
sure it works as an insert. you must use the mono version in a mono channel and stereo in a stereo channel, of course....
Not available as insert means its not in the right place. You can navigate into your ScopeDevices directory and manually COPY the files (so that the old versions stay where they are as well) into the appropriate subfolders under the mono and stereo paths. Then the Vinco will show up as an insert.
indeed, as you also can edit the SFP main menu bar to your convenience...not always obvious to everyone :smile:
