8 Band EQ
Planet Z Announcements
wolf
Post by wolf »
<p align="center"><font size="2" face="Arial, Helvetica, sans-serif"><br><strong><font size="3" face="Verdana, Arial, Helvetica, sans-serif">8 Band EQ</font></strong></font></p><p align="center">8 Band EQ lets you create EQ curves via a graphical user interface.<br>One advantage of the EQ is, that the steepness / bandwidth of any filter is adjustable,<br>so you can easily recreate any EQ out there and have a very good control regarding sound manipulation.</p><p align="center">For requesting a demo, please write a mail to wolfgang (at) worldless.com.</p><p align="center"><a href="http://www.worldless.mine.nu/cgi-bin/dl ... pdf"><font color="#B2C3E7" face="Verdana, Arial, Helvetica, sans-serif">download pdf manual</font></a></p><p align="center"><a href="https://cp.shareit.com/shareit/checkout ... 0&pc=u2ddp" target="_blank"><font color="#B2C3E7"face="Verdana, Arial, Helvetica, sans-serif">Buy online for only 49 €</font></a></p><p align="center"> </p><p align="center"><strong>Features</strong></p><table width="75%" border="0" align="center"><tr><td><ul><li>unloads dsp for unused filters</li><li>adjustable steepness / bandwidth for all filter kinds</li><li>cut, shelf, parametric and notch filter</li><li>12db and 24 dB filters</li><li>most controls tweakable via a big graphical user interface curve</li><li>input and output level display</li><li>adjustable input / output level</li><li>output level display can be routed to show the level between the filters</li><li>available as mono and stereo insert effect</li><li>shows preset name on surface</li></ul></td></tr></table><p align="center"><script language="JavaScript">function klein(bild) {newWin = window.open("http://www.worldless.com/sfp/bild.html?" + bild, "fenstername","scrollbars=0,toolbar=0,location=0,directories=0,status=0,resizable=0,width=1120,height=405");}</script></p><p align="center"><a href="javascript:klein('8BandEQ.jpg')"><img src="http://www.worldless.com/sfp/images/8BandEQ_small.jpg" width="513" height="154" border="0"></a><font size="1"><br></font><font size="1" face="Arial, Helvetica, sans-serif">(click on the pic to view original size)</font></p><p align="center">Different steepness / filter quality settings :</p><table width="514" border="0" cellspacing="0" cellpadding="0" align="center"><tr><td width="300"><img src="http://www.worldless.com/sfp/images/low-q.jpg" width="300" height="96"></td><td width="213" align="center" valign="middle">low cut and high shelf filter<br>with <font color="#B2C3E7">low</font> steepness / quality</td></tr><tr><td> </td><td align="center" valign="middle"> </td></tr><tr><td width="300"><img src="http://www.worldless.com/sfp/images/high-q.jpg" width="300" height="96"></td><td align="center" valign="middle">low cut and high shelf filter <br>with <font color="#B2C3E7">high</font> steepness / quality</td></tr></table><p>kind regards<br>Wolfgang<br>---<br><a href="http://www.worldless.com/sfp">wolf audio design</a></p>
<font size=-1>[ This Message was edited by: wolf on 2005-05-09 11:08 ]</font>
mausmuso
Post by mausmuso »
Hey Wolf,
Thanks for the cool plugin
it was instantly usable
Looks great - works great
mausmuso
Janni
Post by Janni »
anyone tested this eq?
seems like a "missing link" for scope ...
mausmuso
Post by mausmuso »
Hi Janni,
I am using it.
I have found it useful for tricky EQs like some guitar that was poorly recorded.
8 bands allows some real precise surgery on certain frequencies whilst retaining enough bands for general EQing of the instrument to get it to sit in the mix OK.
A couple of issues though:
The Q on the lowest band does not seem to get saved in presets, and
I had trouble trying to run two 8BEQs in the same project. The first worked, but the 2nd instance just hung and no sound was transmitted though it.
regards,
mausmuso
wolf
Post by wolf »
works for me. Can you send me such a preset and tell me, what's the wrong setting and how it should look like ?
mmh, I have now about 10 8BandEQ loaded without any problem. Is this reproducable on your side and could you send me steps to reproduce or a project, where this has happened ?
Wolfgang
mausmuso
Post by mausmuso »
Hi Wolf,
I have retried multiple 8BEQs in another project and it is fine.
I will go back and have another go in the original project. It might have been finger trouble, who knows. Sorry for the bad press.
I will email you the preset seperately.
It is no big deal, but the lowest band Q setting was not being saved. The sharpish notch was being reset to a wide Q setting and it was happening repeatedly as I tried to saved it a number of times.
mausmuso
wolf
Post by wolf »
The issue with the graphical eq curve bandwidth setting in band 1/8, parametric mode, is fixed (the bandwidth knob can now be controlled by the curve, it only worked the other way).
cheers
Wolfgang
<font size=-1>[ This Message was edited by: wolf on 2005-05-24 16:38 ]</font>
