<a name="planetz-file"></a><a href="http://www.planetz.com/Pulsar/files/dev ... .zip"><img src="/forums/images/file_icon.gif" border="0" alt=" File"> File</a><BR> <a name="planetz-tag"></a>Price ($USD): 0<BR> <a name="planetz-tag"></a>Type: Cables<BR> <a name="planetz-tag"></a>Related To: Hardware<BR> _____________________________________<BR><BR> Here is the grafics squematic of Pulsar cables in grafic pulsar Plus and in file two grafics Plus and Classic.
I don´t know if this the adecuate thread for this but is a usefull information
<BR><BR><a name="planetz-fileimage"></a><IMG SRC="http://www.planetz.com/Pulsar/files/dev ... r_plus.jpg" BORDER="0">
Cables for Pulsar Classic or Plus
Hola. ¿Crees que sería posible sustituir las salidas Stereo/Analog out (RCA no balanceadas) por conexiones XLR balanceadas en una Scope Classic? he visto que la única diferencia entre ambos gráficos sería lo conexión o no conexioón de determinadas patillas para la consecución de una salida balanceada.
Sería interesante poder reconfigurar mis propios cables de la scope classic y convertir sus salidas analógicas de no balanceadas a balanceadas. Pero claro...tal vez esto anularía la garantía.
Gracias por la información.
Un saludo
Un saludo
- next to nothing
or as the babelfish would have said:
Hello. Think that out (not balanced RCA) by connections XLR would be possible to replace the Stereo/Analog exits balanced in a Scope Classic? I have seen that the only difference between both graphs would be the connection or not conexioón of certain sideburns for the attainment of a balanced exit. Classic would be interesting to be able to reshape my own cables of scope and to turn its balanced not balanced analogical exits of to. But clear... perhaps this would annul the guarantee. Thanks for the information. A greeting
Connecting sideburns makes sense.
- paulrmartin
UsedManateeSalesman
babelfish is not very accurate in this case, as in most cases
ChampionSound
Hi, NO the hardware I/O in second generation of pulsar, have two versions, one is fully balanced and the other is unbalanced in electronics so if you connect the pins to try obtain a balanced I/O is not possible, this pin it is not connected to any.
Sorry but if you want balanced I/O you need to buy a new I/O plate.
