Moderators: valis , garyb
luddl
Posts: 17 Joined: Wed Jan 12, 2005 4:00 pm
Post
by luddl » Fri Apr 15, 2005 2:10 am
i have 3 cards installed (scope/p2/p1). so , is it possible to add a sync plate without problems? (i would like to sync via wordclock).
alfonso
Posts: 2225 Joined: Sun Mar 25, 2001 4:00 pm
Post
by alfonso » Fri Apr 15, 2005 2:39 am
Of course, it is mounted over one pci slot without using it, it is just connected with an inner cable to one of the cards, I have 3 cards too and connected it to the main one. You must have an unused pci slot space to use it...
Posts: 23395 Joined: Sun Apr 15, 2001 4:00 pm
Post
by garyb » Fri Apr 15, 2005 2:43 am
same here. works great!
braincell
Posts: 5943 Joined: Thu Sep 13, 2001 4:00 pm
Post
by braincell » Fri Apr 15, 2005 3:27 pm
and it needlessly blocks a pci slot... brilliant.
symbiote
Posts: 781 Joined: Sat May 01, 2004 4:00 pm
Post
by symbiote » Fri Apr 15, 2005 4:05 pm
Hmm, where else would you want to put it exactly?
darkrezin
Posts: 2133 Joined: Fri Nov 02, 2001 4:00 pm
Post
by darkrezin » Fri Apr 15, 2005 6:26 pm
Most cases have at least 1 slot bracket which isn't even used by a PCI slot.
BuzzBang
Posts: 39 Joined: Sun Sep 05, 2004 4:00 pm
Post
by BuzzBang » Sat Apr 16, 2005 11:33 am
I've got an A16U and a Noah and 3 creamware cards. Is it worth getting the synch plate for workclock?
How much of an improvement have people experienced?
Will it improve normal audio playback eg cubase, and reduce jitter on CD playback?
I strongly suspect it's a very good idea, just wanted to check before I splash the cash......
I'm using zlink for the A16U and ADAT from the NOAH into the cards btw. So will the biggest improvement be from the NOAH?
<font size=-1>[ This Message was edited by: BuzzBang on 2005-04-16 13:10 ]</font>
Post
by garyb » Sat Apr 16, 2005 12:19 pm
it's a definite improvement, although it's not the difference between good and bad sound. if you use the sync plate, you'll probably want to opt for a high-end master clock generator.
