Problem with NI apps and 32 bit float drivers
Kymeia
Post by Kymeia »
I've been trying to decide on the optimal default setup which will include asio drivers to see if there is a difference in terms of sound quality and CPU (disk space is irrelevent). However when trying the 32bit flt drivers I seem to get horrible noises from the standalone versions of Reaktor and Kontakt - it doesn't affect the plugins. I was hoping to use 32 flt as my standard as I thought since most apps use it internally it would reduce CPU hit but if it's going to clash with some apps should I stick to the 24 bit drivers?
interloper
Post by interloper »
In my opinion, you can use 24 bit drivers and get superb quality.
If you do some processing in the sequencer, just limit the number of operations. A good way to do this is by running the effects live, and then mixing down the entire track.
Kymeia
Post by Kymeia »
Thanks - does anyone know why I get those horrible noises in NI apps though? - I thought most audio apps use 32bit float internally which is why I chose that driver.
Cubase and Wavelab are the the most likely apps to support 32bit ASIO drivers. NI's apps in all likelihood do NOT and therefore you're experiencing some errata.
<font size=-1>[ This Message was edited by: valis on 2005-03-29 21:36 ]</font>
