seq won't load asio drivers
eliam
Post by eliam »
Everything seems fine with scope, the asio modules are in the project but nuendo says "can't load asio drivers".
I have reinstalled scope a couple of times as well as nuendo, without success...
Any hint as to how to fix this?
Thanks!
Normally, ASIO is installed with the client, so Nuendo. When the problem presents itself, I've always gotten away with it by re-installing the latest update of [Cubase].
Also, have you tried opening Nuendo with Pulsar set to samplerate --? Slave SFP to something that has no incoming clock, and Nuendo will, again, say it didnt find any drivers. That also resets ASIO, but on another level than the re-install.
For example, after a Nuendo crash when SFP thinks Nuendo is still using the drivers and upon re-opening Nuendo complains it doesn't find ASIO.
More than that I can't think of :/ Good luck, Eliam!
reinstall the scope drivers in the device manager...
eliam
Post by eliam »
Thanks for the tips, but neither of your suggestions worked... I'm clueless here... I guess I'll reinstall my system from scratch unless I fix it quickly...
Thanks anyway!
Music Manic
Post by Music Manic »
This constantly happened to me when installing scope v4.0.
I got project without mixer too.
Tried re-install then got no registry key found error.
Can't remember how I got around it bit I didn't start Scope when it asked.
Think I re-installed drivers then scope exe.
Perhaps you've reached the '10 Entry Limit'?
http://www.rme-audio.com/english/faq/10entrye.htm
