Is SCOPE home powerfull enough for modular?
I would like to know if SCOPE home card is powerfull enough for Modular II (and III) synth or are there some limitations (probably yes, can u describe its performance?).
BRAiNLoAD CoRE LiVESET PERFoRMACE
http://brainload.freetekno.cz
i think what alfonso meant this: 'from the big library of mod patches, there are some patches you can load, some will need more than 3DSPs to even load one voice."
in short, the only restriction for loading patches are the DSPs, and in some cases pci capacity of your computer. you can load a bunch of lightweight patches on a ScopeHome, but the heavy stuff won't be possible, especially if you want polyphonic things going on.
andy
the lunatics are in the hall
I need it for hardcore / breakcore / tekno production. Mainly for FX and lead, so in most cases I will be happy with one voice only.
According to percentual DSP load of modules presented at http://www.modularsynth.co.uk it seems to be enough (3 DSPs) for me.
Another GREAT site for modules and DSP uses :
http://www.cwmodular.org/
You need 6 DSP at least to start moving with synths, modular and FX ... I mean at 44.1 / 48 Khz you can load a single instance of whatever at one voice minimum except for heavy modular patches and Solaris 3 at full power ...
Please, can somebody post a link to example screenshot (and/or mp3 sound example) of what can be done on 3 DSP card at 44khz resolution / one voice. But not the simplest one, I think someting with moderate load of 3 DSP card.
Thanx a lot.
Thanx a lot.
I think this one will nearly max out a Scope Home, at one voice. Add a small mixer to mix it with ASIO to Analog Dest and you're there.
I removed the picture to keep this page readable at 1024x768.
Nice, thanks a lot. I think 3 DSP will be good start for me
