Greetings,
 No matter what I try and use I just cant seem to find the correct way to link 2 matching controls, I have tried onn/off switches, buttons, and cutters and nothing does the trick as I would expect it too.
 Any one care to give me a tip on how to accomplish this task either here or by PM please?
 Thanks in advance!
						How to create an on/off toggle to link paramaters?
				Basic Pitch
Actually,
I have tried using that same unit as you describe but try this and you will see the issue.
Drop 2 copies of a filter or an envelope side by side and open the surface of both, then from the antenas of each device place a cut between each corresponding antena, now you will see green connections on (one)complete connection and blues on each other, if you then move a pot from any of the paramaters you have linked from the surface you will see that one pot will link properly and the pots will move together while the ones with the blue connections will not function in a linked state and if you connect all cut antenas they will function as one giant cut switch.
What I am trying to do is link 3 different paramaters from filters hp,lp,res allowing them to either function as a linked device or as a sepearate pot, but I am unable to get them all to link properly unfortunately.
Any ideas?
<font size=-1>[ This Message was edited by: Basic Pitch on 2005-03-13 15:07 ]</font>
Any ideas?
