Autostart and ASIO
Music Manic
Post by Music Manic »
Hi just upgraded and getting this problem on different partitions all the time now.
Scope doesn't autorun on startup into XP plus sequencers don't have ASIO option.
When I've installed Scope v4.0 in comes up which XTC page asking if I want to enable ASIO etc.
that "XTC page" is just an app that runs initially to allow you to set some options. Everything there can be set later either in SFP's settings pages or in the ControlPanels>Sounds&AudioDevices>Hardware>Pulsar2_Properties>Settings tab.
In regards to your startup project, if you run SFP.exe and go into the settings you will find the option to enable the startup project on one of the settings pages. You can also disable XTC mode there and set everything else as you need.
In order for ASIO drivers to be seen by your Sequencer you'll need to load ASIO drivers into your project(s).
Music Manic
Thanks.
Had ASIO loaded but it didn't recognize them.
Re-installed drivers and all is well.
