 before             the signal can be manipulated by an INSERT EFFECT and ends up in a             main mixer where all signals can be adjusted individually; now there             is a MASTER INSERT allowing you to freely decide IF and WHAT effect             you use. the demos are restricted to the provided sounds. it is not             possible to load other akai files. there are different presets providing             all possible combinations of the included sounds. the macintosh demo             version does not contain the sonoquid dee-lay. the .zip file contains             a direct link to the download location. the demo is 13,5 mb big! have             fun!
 before             the signal can be manipulated by an INSERT EFFECT and ends up in a             main mixer where all signals can be adjusted individually; now there             is a MASTER INSERT allowing you to freely decide IF and WHAT effect             you use. the demos are restricted to the provided sounds. it is not             possible to load other akai files. there are different presets providing             all possible combinations of the included sounds. the macintosh demo             version does not contain the sonoquid dee-lay. the .zip file contains             a direct link to the download location. the demo is 13,5 mb big! have             fun!SONOQUID DEMO for WIN
				Guest
This file has expired and is no longer available here. The owner of the topic can re-upload the file, or post a link to an off-site file. <BR><BR>_____________________________________<BR><BR>             this device is based on two SAMPLE ENGINES, each capable of loading             two akai programs; each ENGINE has it's own ENVELOPE and PITCH SECTION             and can separately be routed into three FILTER SECTIONS; let the filter             be modulated by an LFO or an ENVELOPE or simply adjust it manually;             the next step could be BALANCE MODULATION ( depending on you  before             the signal can be manipulated by an INSERT EFFECT and ends up in a             main mixer where all signals can be adjusted individually; now there             is a MASTER INSERT allowing you to freely decide IF and WHAT effect             you use. the demos are restricted to the provided sounds. it is not             possible to load other akai files. there are different presets providing             all possible combinations of the included sounds. the macintosh demo             version does not contain the sonoquid dee-lay. the .zip file contains             a direct link to the download location. the demo is 13,5 mb big! have             fun!
