Adding some snap to drums
				Counterparts
Hi CP, I did that in my latest song Bazurk (now called Last Tango).
It's a nice trick indeed, because you get nice variation possibilities, by filtering or eq-ing one of both drum tracks, without drifting away from the initial idea too much
F.e., in the intro you can hear the 'original' beat, but with a highcut filter applied.
Then, after a while, both beats together take it over.
Also you can hear several res-filtered fills built from that beat.
cheers.
cheers.
				King of Snake
Fun topic!
With a compressor: raise attack time untill the initial snap of the drum gets through uncompressed.
Using expansion of the highest levels with a short attack and quick release.
By EQ: You can amplify the initial snap of a Kickdrum by raising some higher frequency levels - the snap has a high frequency. Sometimes a hihat can by made less snappy by cutting some lower freq's (HPF?), where the initial tapping of the stick is.
DIY: Hook up an envelope follower (the one from Flexor is very fast), half-invert it. Now let that amp-modulate the drum sound. For example with a ringmodulator, VCA or even AmpMod. Congrats, you've made yourself a compressor
  Want an expander?  Get rid of the Half-Invertor.
Now you could cut the lows or the highs before the EnvFollower's input. This will make compression only react to the remaining frequencies. There's a topic on cross-over, so you can even do multi-band dynamics with that.
				Counterparts
I found that after adding the pitch-shited drum(s) and tweaking the relative levels (this affected the pitch/tone of the drum as well as the added snap), for the snare particularly I needed to then re-adjust the compressor settings to squeeze off a some of the additional snap that was created.
I found it worked well for all of the percussive elements; snare, bass, hats and cymbals although they each needed a different amount of pitch adjustment, relative levels, compressor tweaks etc. Different qualities of the sound can be enhanced/improved; presense & brightness as well as the "snap" of the drum.
In comparison, I found that more subtle changes could be made using this technique than e.g. using the Transient Designer.
Royston
Royston
				Counterparts
Hey great stuff,
Just want to add stereo detune works great on anything not just on drums. Try with synths, instead of the usual detuning of 2-3 oscs for sound, try panning 1 osc left, another to the right and then detuning.
Elmooht - Faxi Nadu - Cider Groove
Postunder Records @ http://www.postunder.com
@ Atomic -
You rock, thanks for another great and clear explanation and tips.
