Noah continous controllers - midi control
Nebukadneser
Nebukadneser
Yes, you are right. The midi table in the technical reference displays the CC numbers for almost all devices.
The 16 parameters that appear when you right cilck in Noah remote are parameter sets controlled by the yellow knobs on the NOah itself.
But the insert effects (2 pr. channel) is remotely controlled by "KeyP NuberA/NumberB" - could someone explain what Keyp means, and how to go about to remotely controll the inserts?
Neb
Neb
Yes, I think the controller no's of all of the devices are indicated in the manual with this 'KeyP'. I've no idea what it stands for ...just that it's the controller no's you use.On 2005-02-09 15:45, Nebukadneser wrote:
As for the inserts - I've not tried it yet but I was assuming that the two numbers were for the 2 inserts so let's say that you wanted to control 'Freq 2' on a parametric EQ , you would use either controller no. 73 (for insert 1) or 93 (for insert 2).
Shark put me on the right way...I didn't know what keyp was .. . :
It's "Poly Pressure" Controller.
It's not a standart controller. Look in your favorite sequencer. When you choose this controller, you must choose first a note number and after you write your control.
This means there are as much controls as notes, in this parameter..so ..a lot!
this is why the noah uses a lot this controller, Poly Pressure can generate an awful lot of MIDI messages.
cheers.
cheers.
kybernaut_01
This question seems not finally answered...
Say, I have an external MIDI controller box with 16 knobs.
Say, I don't want to program a template for each Noah instrument that I want to control from that box.
Now, I remember that Noah instruments have already assigned the 16 most important paramters to the so called "performance controllers" (yellow knobs).
I ask myself (and you), why couldn't I set up my external controller box to mimic these 16 performance controllers, so that I have automatically access to the 16 most wnated parameters of an instrument?
Can I do this?
Can I do this?
The normal way to do such thing is to program presets on the controllers rather than on the noah itself.
Anyway, you would have to make some templates for that either on the noah or on the controller...
In fact, it seems that the CC Control assignment is fixed on each of the NOAH synth. So you need to make the templates on the controller.
CheerZ
CheerZ
CheerZ
CheerZ
