S/TDM cable a straight-thu ribbon cable?
irrelevance
Post by irrelevance »
Getting extremly impatient now and will be in the position to knock up a cable at work tommorrow. Can anyone tellme how many lines te cable has?
Stubbe
Post by Stubbe »
The cable has 20 wires, and for what it's worth it's marked **2651 VW-1 E126B**, stars indicating possible characters covered by connectors (last "B" could be "8", not sure...)
The connectors are marked 6338 ELCO EG/YK As long as you place these facing the same way on the cable, you should be OK.
Good luck !
Stubbe
fidox
Post by fidox »
yo!
also check here,
i have once asked that here before;
http://www.planetz.com/forums/viewtopic ... 60&forum=5
good luck :smile:
irrelevance
Thanks fidox that part number has saved me some time sourcing.
Found the connectors here: http://rswww.com
Part number: 120-9983
<font size=-1>[ This Message was edited by: irrelevance on 2005-02-01 08:20 ]</font>
fidox
Post by fidox »
cool,
np :smile:
matej
irrelevance
I didn't check your part number stubbe but I think Elco are usually cheaper parts compared to 3M. I'll try looking those up now. Thanks peeps :smile:
<font size=-1>[ This Message was edited by: irrelevance on 2005-02-01 09:17 ]</font>
irrelevance
Ok found the elco's here: http://farnell.com
part number: 635730
Almost a third cheaper! :wink:
krizrox
Post by krizrox »
Plain old 40 conductor IDE cable works fine too. Just carefully trim away the unused portion of the cable with a razor blade.
Stubbe
Post by Stubbe »
Glad to help, and hope you get it ticking nicely soon.
Stubbe
