adat inputs...
annecyops
Post by annecyops »
Hey what's up everyone, I'm having a wierd problem with the adat a & b inputs in my card. My setup is my G4 with an RME Multiface which is link externally to the pulsarII via adat. When I access the adat a/b source on the routing page and then patch it to the mixer, the right side has this crazy like 12k signal that won't go away, not even when I change adat cables or anything else. This is the second time that I used the adat going into the pulsarII. I don't know I'm kind of thinking that maybe it has something to do with the outputs being plugged in as well, because the 1st time that I used the adat inputs it worked, and I didn't have any outputs going on. But why should the outputs being in use be a factor. Anyway, can some super pulsarian guru give me some advice?? Thanx
annecy
It's nothing special, we just check the z quite often :razz:
How's your sync settings? You may want to slave Pulsar to the RME, see SFP > Set > Samplerate.
