Vinco for Drums
It has also 2 different modes. The default is "limiter" but there is also an rms mode more "compressor" like.
I posted some presets copied from other famous soft compressors, maybe you can find some good starting settings:
http://www.planetz.com/forums/viewtopic ... forum=13&2
I tried with different attacks but I don't like the result. Also using the input knob to the max (that means increasing the threshold) I can only hear a volume raising but not punch, or very few punch.
Using the compressor of the mixer 24/48 I achieve far better results in terms of punch.
Other good compressor for Pulsar ?
No, increasing the input would mean lowering the threshold.On 2005-01-29 10:31, claudioD wrote:
For maximum "punch" you should set the attack to full and the release to minumum.
On a full mix I engage the RMS seting too, this way it works more like a maximizer.
I love vinco and use it on everything basically. I use the mixer compressors for side-chaining mostly.
EDIT:
Actually, I believe Vinco has a fixed threshold.
<font size=-1>[ This Message was edited by: voidar on 2005-01-30 19:28 ]</font>
Well, I mostly deal with guitar, bass and drums, and some vinco can be desireable.On 2005-01-29 16:26, braincell wrote:
So you use the vinco at the end of the chain and on everything? I bought the Vinco and so far it seems best for use with a microphone (with a hardware compressor prior). I am thinking maybe I should have bought the optimaster instead.
My usual mixing procedure would be to have a compressor on each mono track (if needed), and then I would bus these tracks into suitable groups with their own compressor.
The last stage would be mastering with additional compression, but it is a separate process.
The whole chain could be like this:
drumX -> vinco -> buss1
bass -> EQ -> vinco -> buss1
guitar1 -> EQ -> vinco -> buss2
guitar2 -> EQ -> vinco -> buss2
buss1 -> vinco -> master
buss2 -> vinco -> master
master -> finaliza/multiband -> EQ/ISON -> vinco
Vinco is my compressor of choice.
The only outboard I use are micpres, DI's - proper level-matchin hardware in general. I get all the S/N-ratio I need when recording at 24 bit.
King of Snake
a limiter is just an extreme form of a compressor no?On 2005-01-29 05:12, claudioD wrote:
I tried different settings of Vinco but still I'm not able to obtain a satisfactory punch. Is Vinco more a limiter than a compressor, or it's only my opionion?
I think the term "limiting amplifier" is a bit confusing because Vinco technically doesn't have a limiting setting (ie. compression ratio of infinite:1)
but I think it works very well on drums actually. I always set the display to PPM so I can actually see what I'm doing in terms of gain reduction. Adjust the input knob until you get something like 6db reduction (for starters) then turn up the attack to something like 10ms or higher and turn down release. That should give you some punch. All depends on the source material and the desired result of course.
King of Snake
Optimaster and Vinco are of course totally different things. I like to use Vinco on the stereo mix though, but very gently on RMS setting with 2 or 3 db reduction, but of course it doesn't do all the stuff an Optimaster does, just compression.On 2005-01-29 16:26, braincell wrote:
ernest@303.nu
Although I really like Vinco on drums, the Transient Designer can indeed do miracles to drums. I once recorded a funk/blues band and the recorded drums sounded much too whooshie, if that means anything to you
Slightly increasing the attack and decreasing the release made the drums really stand out in the mix. The drummer liked the sound very much. You can't replace a compressor with it, but for messing with attack and release times it's really top!
