I get and issue with the polyphony. My Synth was working correctly and suddently with SFP4 it only works in mono.
As soon as I add more voices the synth drop midi info and plays only every 2 notes (for a 2  voices setting) 3 notes (for a 3 voices setting) and so on.
If I load the Empty Synth and create a small synth with juste a 'Voice Control 16' + OSC I have the same issue.
Does the DynVoiceofParent atoms has changed in the last SDK version? Does anyone else has the same issue.
Note : this seems also to be the case with the Neutron Projects...
						Problem with DynVoiceofParents
				Shayne White
You're using the PolyOut16 (or something like that) module at the end of the polyphonic chain, right?
							Melodious Synth Radio
http://www.binary-sea.com
