pulsar, cubase and reason
- Mr Arkadin
dubcotics
hi,
for that you have the ASIO drives, provided REASON and CUBASE are switched to ASIO. Ah! you can use REASON along side with Cubase sx via REwire. you should be able to use both sequencers at the same time and consquently apply Scope fx, cheers.
didier,
ps: tho I haven't tried I guess it's done like that. Well someone will turn up with some better explanation.
didier,
Kalinski
I can split the outputs from Reason into Cubase, but i can't work out how to split those into pulsar?
From memory i used to use the bus in Cubase and that used to give me seperate outputs in pulsar.
because of computer problems (and lack of money)it has been a year since i have used pulsar regularly!
cheers again
cheers again
King of Snake
