Another thing for CreamWare to work on
Shayne White
Post by Shayne White »
In addition to their Linux/Mac developments, they'd better start working on a 64-bit version of Scope so it can work with Windows XP 64-bit and Sonar x64. Otherwise, it'll become absolete on Windows as well as other platforms... :sad:
PCI-E and new DSP chips would be nice, too. :grin:
Oh, and only DirectX works with 64-bit. Cakewalk says VST needs a complete overhaul to be 64-bit compatible. So CWA had better work on a DX version of XTC, too.
I hope they're busy!
Shayne
Melodious Synth Radio
http://www.binary-sea.com
On 2005-01-25 17:27, Shayne White wrote:
...Otherwise, it'll become absolete on Windows as well as other platforms... :sad:
the only thing that is obsolete is a 64-bit OS for Workstations... :razz:
time_chase
Post by time_chase »
wont Win XP64 be compatible with the 32bit stuff? I dont think many developers would be in a hurry to get 64bit going...XP64 aint even out...knowing MS it will be delayed for another 2yrs!! The OS is still a long way off.
The rage in 2005 will be dual core cpus....that's something to look forward to.
wsippel
Post by wsippel »
time_chase,
no. You may use 32bit software on Win x64, but _not_ 32bit drivers. And, if I can draw a conclusion from using 64bit Linux, it's not always possible to 'connect' 32bit and 64bit applications (exchange informations - ASIO drivers come to mind, or 32bit VST plugins may not work on a 64bit plugin host without some 'magic' in the host...).
Yeah, and 640kB will always be enough... :smile: I like my 64bit OS, and it _has_ it's benefits!
<font size=-1>[ This Message was edited by: wsippel on 2005-01-25 21:15 ]</font>
which of them are relevant for non-esotheric purposes ?
Shayne White
Well, according to Cakewalk, there's extra CPU power that can be used, and you can have a terrabyte's worth of memory. You can buy enough memory to load your entire projects into memory and never have to do disk streaming. GigaStudio will be out of a job. :grin: :grin: :grin:
wsippel
Post by wsippel »
Increased per-process memory space, increased phyiscal memory size (without address translation), increased virtual memory pool size, 64bit integer opps in a single CPU cycle (faster/ higher precision), double the integer registers + double the register size, 8 additional SSE(2) registers - not much, but worthwile nevertheless... :smile:
Some info on AMD64 vs x86:
http://h200001.www2.hp.com/bc/docs/supp ... 238028.pdf
darkrezin
Post by darkrezin »
I'd like to see some PC motherboards with more than 4 RAM slots :wink:
wsippel
Post by wsippel »
dArKr3zIn,
8 slots (Workstation boards. Up to 16GB):
http://tyan.com/products/html/thunderk8we.html
http://tyan.com/products/html/thunderk8w.html
16 slots (Granted, server board. Up to 32GB):
http://tyan.com/products/html/thunderk8qspro.html
<font size=-1>[ This Message was edited by: wsippel on 2005-01-25 22:50 ]</font>
kensuguro
Post by kensuguro »
don't worry about the slots. By the time you can afford to fill them up, they'll come out with some new standard and make all your RAM obsolete.
wsippel
Post by wsippel »
AMD plans not to move to DDR2 'tll late 2006 - that doesn't mean they'll not use DDR533 or something like that this year, of course...
I'd consider the first 2 points esotheric (in the workstation, not server, context), I agree on the improved integer processing and the last 2 points are CPU (not OS) related.
In fact that's pretty few :wink:
There is not a single cycle of performance increase by such an architecture, but the adaption of the majority of data to 64bit will cause a massive overhead of processing.
Some major suppliers didn't even manage to get a 16bit OS right, and most of current 32bit software is buggy as hell. All to be recompiled with new error introduction :razz:
It should be clear that the driving force behind this is 'sales, sales, sales'. It's new, it's bigger, it's better - a welcome justifice for a lot of companies to continue business instead of moving their stuff where it belongs.
You have mentioned the 'Bittware' pages with their TigerSharc boards and tools.
There's an excellent examination about the obstacles for an optimized algorithmic design on a DSP and a (RISC) CPU (TS versus G4).
THOSE are THE problems that have to be solved for performance increase at the workstation level - and those problems are completely OS independant :wink:
wsippel
Post by wsippel »
Of course, the additional registers are not really 64bit specific. But there is no other way to introduce them on x86 (and have them used on a large scale). And the double register size is 64bit specific, of course...
The improved memory addressing is not only suited for servers, btw. Using worksataion apps like Softimage|XSI, per-process memory requirements are not uncommon to exceed 2GB (this also includes swap and shared memory of course), and since systems with 2GB RAM are not that rare anymore, it's likely we'll see systems with 4GB - 8GB RAM next year, something hard to accomplish using 32bit architectures in an efficient way...
The ability to process 64bit ints in a single cycle also much improves the performance for specific operations - see oggenc and other audio/ video codecs for example - speed improvements of 350% are not uncommon. In fact, processing of longs is about 7-8 times faster on a 64bit OS with current compilers like gcc 3.4, and expected to improve even more with gcc 4.x...
darkrezin
Post by darkrezin »
On 2005-01-25 22:48, wsippel wrote:
dArKr3zIn,
Hi Willie..
Yes, I was aware of server boards... but I think it's still quite rare to use these kind of boards for DAW systems. I sure wish I had one though!
wsippel
Post by wsippel »
Well, the K8W series are workstation boards - who would need an AGP slot in a server?
Especially the K8WE should make an extremely powerful DAW, but it's quite expensive I'm afraid. :sad: It has an unbelievable bandwidth, as half the PCI(X) slots are connected to CPU1, the other slots are connected to CPU2. Same goes for PCIE, one connected to each CPU - that makes the K8WE the only board with two PCIE 16x slots on the market...
<font size=-1>[ This Message was edited by: wsippel on 2005-01-26 16:04 ]</font>
darkrezin
Post by darkrezin »
Yeah... cost is definitely a barrier :sad:
I look forward to the day that consumer boards get this kind of functionality (I'm not holding my breath....)
rob604
Post by rob604 »
Actually you can get dual PCIe SLI boards for much cheaper than the dual-proc Tyan from companies like Asus, MSI and/or Gigabyte. <a href="http://usa.asus.com/prog/spec.asp?m=A8N ... s=09">Asus A8N-SLI Dlx</a> would be my choice.
Basic Pitch
Post by Basic Pitch »
I dont think its going to be an issue any time in the near future, all people will do is what they have done for ages now any way.
Just run a dual boot system one boot to Win64 and one with XP pro on it. Its the same as not with some people refusing to leave Win 2000 or even some who still use 98SE.
Cheers!
wsippel
Post by wsippel »
rob604,
yes. But you wont find a single CPU board with two full speed PCI-E slots... :smile:
The total PCI(X/E) bandwidth of the K8WE should reach at least 16GB/s, plus 8GB/s for CPU<->CPU communications, and additional 16GB/s memory throughput (2x3 1000MHz DDR 16/16 HT links).
EDIT: To quote ASUS' page:
*SLI mode : x8 , x8
*Default(Single VGA) mode : x16, x1
<font size=-1>[ This Message was edited by: wsippel on 2005-01-27 17:38 ]</font>
rob604
Post by rob604 »
man those numbers make my head buzz.... whatever would you do with all that bandwidth? you are, of course, correct, wsippel - 16x slots. i guess you'd need two cpus just to handle that overhead. :wink:
