SX 2.0 Cannot load asio scope
Jolly
Post by Jolly »
I use 3.1a software.
I changed the driver settings in SX[device setup][VST multitrack] cos I needed to use the onboard soundcard. When I try to change back to asio scope it says it can´t be loaded. What do I do to load the asio scope?
Sorry I´m a newbie...think and hope there is a simple solution.
Herr Voigt
Post by Herr Voigt »
Maybe rebooting is not necessary.
Close Cubase and startup Scope.
Sometimes an application moves away the ASIO Scope drivers. A simple startup should help. Good luck.
Jolly
Post by Jolly »
Cheers guys - I´ve now tried both but didn´t work!
Wonder what´s going on...any other suggestions?
XTC mode isn't enabled is it?
