<a name="planetz-file"></a><a href="http://www.planetz.com/Pulsar/files/dev ... .dev"><img src="/forums/images/file_icon.gif" border="0" alt=" File"> File</a><BR> <a name="planetz-file"></a><a href="http://www.planetz.com/Pulsar/files/dev ... .txt"><img src="/forums/images/listen_icon.gif" border="0" alt=" Sound Example"> Sound Example</a><BR> <a name="planetz-tag"></a>Price ($USD): 0<BR> <a name="planetz-tag"></a>Type: Synth<BR> _____________________________________<BR><BR> This will be updated to an SFP type device.
neutron devices with "3" in the name are not version 3 of the device, they are SFP type devices.
One synth, 2 sets of knobs..it morphs between them. also includes the Neutron "Frag" oscillator, which moves in time.
The midi chan number not remembering problem came back with pulsar 3.0 now it is fixed again
<font size=-1>[ This Message was edited by: defex on 2002-03-03 10:59 ]</font>
<font size=-1>[ This Message was edited by: Neutron on 2002-06-08 13:07 ]</font><BR><BR><a name="planetz-fileimage"></a><IMG SRC="http://www.planetz.com/Pulsar/files/dev ... planet.jpg" BORDER="0">
						-=NEUTRON=- Transplanet Synth 1.0
				algorhythm
The main thing I like about this synth is the oscillator section.  Six (6) oscillators per voice!  They are divided up into two sides, each with 3 oscillators.  You can then "sequence" between these 3 oscillators (which can each have different pitches if you wish), rythmically.  There is a "smoothing" slider that lets you adjust the smoothness (crossfade time?) of the sequence between each oscillator.
The each trio of oscillators can be modulated by an LFO which reaches into Audio Range.
Then, you have a "Morph Envelope" which lets you assign After Touch to morph between each trio of oscillators, or the LFO, or...
The sounds that come out of this sound FM like, or very textured, awesome for evolving drones and robotic noises.
Did I mention that it looks pretty darn cool too?
Small update
Remembering midi chan when loaded with project
midi can change on menu thingy
clicking from envelope generator fixed.
this has the same filename so if you have any presets in your current transplanet save them. (or rename this one)
DeFex
<font size=-1>[ This Message was edited by: defex on 2001-09-09 12:03 ]</font>
DeFex
				algorhythm
				marcuspocus
bump for update.
the "midi chan not loading with project" problem came back with pulsar 3.0 it is now fixed again. you can use this version with your old presets. there are no other changes.
DeFex
argh i forgot about the LFO graphic bug AGAIN!
<font size=-1>[ This Message was edited by: defex on 2002-03-03 11:03 ]</font>
DeFex
