problem with audio quantize
firubbi
Post by firubbi »
What I record a midi track and than re-record in audio track, audio comes ahead about 1 fream! So when I’m running midi and audio together it seems something is wrong with the song. Seems kind’a quantize problem. Can’t understand how to fix it. I’m using sonar… does any cubase user have the same problem? Shayne white once put a topic but didn’t find that. Is that anything to do with Master clock (like apogee bigben)
No, it's an offset you can correct for in your sequencer. Check it's manual! While adjusting the offset, do some tests with for example kickme (or something else very punchy) and make sure MIDI and audio allign properly. Do the same by playing back audio and recording it again on another track thru SFP. In Cubase, I would adjust that by 'Record placement offset' I think it's called...
firubbi
Post by firubbi »
oh ya thanks atomic. it works :smile:
