My setup is Intel 24GHz on a P4B533 with 2 Luna(ULLI) cards and 1 Pulsar1(non UllI) card. When I set the latency to 3ms @44.1k or 4ms @44.1k and use a convultion reverb (Pristine Space) with low latency (64 samples)on an input channel or any other signal that comes strait from the ASIO interface in Logic Audio 5.1, I get clicks and plops. If I increase latency in SFP, they disapear. I checked PCI latency with a little applet that showed 96 for the ULLI cards and 128 for the non ULLI Pulsar 1. I was wondering if it would help to upgrade the Pulsar 1 card to a Pulsar 2 to get better performance. Did anyone overcome this problem by upgrading or should I spend my money to something else?
Best regards,
Marc de Ruiter
Will I get less clicks and plops using only ULLI cards?
Second generation cards are more solid. You can try some tweaks first, but I also had a mixed configuration with 2 p1 and a p2. Changing the 2 p1's for a single Scope definately solved a lot of my headaches.
Marc de Ruiter
