<a name="planetz-file"></a><a href="http://www.planetz.com/Pulsar/files/mod ... .zip"><img src="/forums/images/file_icon.gif" border="0" alt=" File"> File</a><BR> <a name="planetz-tag"></a>Type: Switch module<BR> <a name="planetz-tag"></a>Pulsar Version: SFP 3.1<BR> _____________________________________<BR><BR> I tried a modified button with the light indicating wich stereo pair is selected as input...I hope you find it functional. It's not a typical toggle switch a la minimoog, you only need to click on it.
<BR><BR><a name="planetz-fileimage"></a><IMG SRC="http://www.planetz.com/Pulsar/files/mod ... Sw2to1.JPG" BORDER="0">
Module: Stereo Switch 2 to 1
- alfonso
- roy thinnes
Alfonso, what I especially like with your devices is that they always are an attempt to make things clearer.I often wished to have A/B switches, not the confusing ABCD switch if you only have two choices.And here you have two of them in one single rack unit.thanks!
ps damn, forgive my arrogance but what about two independent switches A/B C/D small as this one?
<font size=-1>[ This Message was edited by: roy thinnes on 2005-01-10 21:11 ]</font>
- alfonso
- roy thinnes
exactly.The aim should be to have as many possibilities as possible without losing track.As I stated in Immanuel's posting about Device Ethic/cloning devices, I was getting a bit jealous when I studied the NordModular manual seeing modules that combined features in a single unit where you need several modules in ModII/III.Or, if you remember ol' ModI which had a Envelope with integrated VCA...
- alfonso
- alfonso
Roy pointed me the fact that this module, together with the Dual Switch, is only monophonic!
I had forgotten to check for polyphony, because I wanted to use them as switches for audio signals from outside the modulars, and i should have done them with a monophonic surface...
I'll try to make them polyphonic a.s.a.p.
Sorry...
Sorry...
