<a name="planetz-file"></a><a href="http://www.planetz.com/Pulsar/files/mod ... .mdl"><img src="/forums/images/file_icon.gif" border="0" alt=" File"> File</a><BR> <a name="planetz-tag"></a>Type: Module<BR> <a name="planetz-tag"></a>Pulsar Version: SFP 3.1<BR> <a name="planetz-tag"></a>Requires: Modular 2<BR> _____________________________________<BR><BR> Here's a new module for the modular.  Use it to  crossfade between 3 osc or ???
02-Jan-2005 V1.01 Updated to save settings in presets and use Mod2 style jacks.
Well, as you can see I figured out a way to make a new module with the SDK.
Hope this works for everyone.
Modulation is nil at center.  Negative values invert the modulation signal.
<font size=-1>[ This Message was edited by: rcaia on 2004-12-28 10:39 ]</font>
<font size=-1>[ This Message was edited by: rcaia on 2005-01-02 09:34 ]</font><BR><BR><a name="planetz-fileimage"></a><IMG SRC="http://www.planetz.com/Pulsar/files/mod ... ay_Mod.jpg" BORDER="0">
						3-Way Crossfade Module
hi rcaia
this module very good but has small bug
when conect InR - saw osc , InC - pulse osc , InL - sine osc so Xfade knob left = saw , center = pulse , right = not sine ( crossfaded pulse and sine )
Tip to new 3xcrossfade module
- left center right
- bipolar mod source l-c-r and r-c-l ( not only r-c and c-l )
- crossfaded left-center-right ( not left-center or center-right )
( fantastic for multi osc pad sound )
Very thanks
- left center right
Very thanks
Updated the module... poor midnight quality control.
Module should now Xfade L->C->R.
Modulation source should be bipolar to get full range modulation. Like the standard modular Xfade if the Xfade knob position is other than center the modulation will only Xfade partway to the other side. (The modulation is added or subtracted to the Xfade knob setting).
Look for another module in a few days... 3xOsc (Waldorf->Saw->PW).
Unfortunately SFP repeatedly freezes/crashes when I try to remove (or even disconnect) the module :/
- Ben Walker
Re: 3-Way Crossfade Module
V 1.01 now available for download here.
If anybody has the previous version let me know and I'll upload that too, if there are problems with this version.
Ben
Ben
