Hi guys
I now have evrything working great (XP pro + SX2 + 2x Pulsar 2s).
BUT.......
If I try to change field values (say bpm in XTC Multitap), the 'text editor' (box) in the app skin won't take the new value, and then does this strange alternating between 25 bpm and 163 (or whatever), not accepting any value in between.
Am I pressing the wrong keys? Do I need german keyboard setup in this partition?
I bet one of you knows the answer!!
>>CHANGING FIELD VALUES IN XTC APPS
Indeed, it's been asked a couple of times before
http://www.planetz.com/forums/viewtopic ... 9&forum=32
Thanks for the fellow sufferer link, Atomic -It's nice to know it's not just me.
It strikes me that IF the
-XTC fx are disgregarding track bpm
-keep reverting to these apparent default values (of 25 and 163 or whatever)
Then it must be feeding off something - even if that's just coded defaults - and those could be changed.
Is this something now fixed in Scope 4?
Whether or not it is, someone out there must know an answer or a workaround
Go to the instrument track and enable Read. For an insert effect, you have to cycle Write on/off too, since it has no track by default.
Now on the track, open VST automation subtrack, usually it's set to Volume by default. Instead of that Volume, select BPM or delay time. Now you can draw/set that parameter.
So the only way to set the BPM and delay time parameters for these XTC devices is by VST automation instead of on the device's GUI.
SFP4 is what I was talking about, same in older versions w XTC support
