Timeworks Plate P-100 problem loading in ScopeFX (But no pro
beerbr
Post by beerbr »
I can't load p-100 in new ScopeFX series. But with Scope 4.0 I can load without problem. Does anyone find this problem or how to fix it?
Thanks..
o.k., first with the obvious questions...
is the p100 in the appropriate devices folder in scope fx and then did you enter the key when prompted?
beerbr
Post by beerbr »
Yes.. I put it in the right folder and I enter the key when prompt..
I copy device p-100 in the effect folder, and I put the cp2 (copy protection) in the app/dsp folder. I did it the same way I did when I install p-100 in my Scope 4.0.
When I load device in ScopeFX, they said about error in file cp2 (copy protection) and I can't load. I doubt because I always use licence products and never mess with any crack one in my computer.
Thank you.
is that file marked "read only" in properties? if so, uncheck.
maybe try recopying the file if all else fails... i would expect it to work.
i don't remember but i believe there was an installer program, or maybe you have a mac?
<font size=-1>[ This Message was edited by: garyb on 2004-12-22 04:10 ]</font>
beerbr
Post by beerbr »
No..
I'm sure I did it right but I think they might me some conflict with P-100 and ScopeFX.
The error is like..
Can't find DSP file st cp2. Please check the installation..
But I'm sure I did it right. May be Warp69 (who made p-100) has to take a check with compatibility..
voidar
Post by voidar »
What if you would look for cp2.dsp (or something) in your SFP directory and copy it to FX?
beerbr
Post by beerbr »
I've done it already..
It has the file name cp2.dsp in DSP directory already both in Scope 4.0 and Scope FX.
But Scope 4.0 can load device without any problem..
did you ACTUALLY try and copy the file ANYWAY? it may help if the file is corrupt. is read only unticked?
Warp69
Post by Warp69 »
Hey beerbr,
Unfortunately I dont have a fix yet. I dont have access to the SDK or the new Scope FX - I have to talk to Creamware regarding this problem.
Cheers
beerbr
Post by beerbr »
Yes I did copy it manually. That file 'cp2' has to copy manually from p-100 setup anyway because it won't be at DSP directory in the first place..
I was using Pulsar II for 4 years already. I know quite very well inside in and out of the system. Actually I would know if something is wrong.
It seems that this conflict is with the system in ScopeFX and need to be fix either Warp69 (who make P-100) or Creamware.
Thank you..
PS. Does anyone know this problem? and ACTUALLY use the ScopeFX with P-100?
beerbr
Post by beerbr »
Oh.. I just see your message after I post last one..
Thank you warp69.
Do you know estimation time of the fix?
Thank you.
no problem, i was just checking to see if you tried to copy the file again, or if you just assumed that because you copied it once it was right.......
beerbr
Post by beerbr »
Yeah.. I can did it now..
The reason is because the version of my ScopeFX (TripleDAT LE) is old.
I've just download the new version today and it can work without problem..
Thank you everyone =)
:grin:
