Moderators: valis , garyb
fra77x
Posts: 889 Joined: Tue Apr 17, 2001 4:00 pm
Post
by fra77x » Fri Dec 17, 2004 5:58 am
Is there any relation to the behavior of delays... I have problem with tempo synced delays...
Posts: 4744 Joined: Sat Jun 30, 2001 4:00 pm
Post
by at0m » Fri Dec 17, 2004 3:36 pm
Which problem where when?
Posts: 8487 Joined: Fri Feb 08, 2002 4:00 pm
Post
by astroman » Sat Dec 18, 2004 4:34 pm
of corse there is a relation as both SpaceF and Warp69 include ULLI in their settings...
Warp69
Posts: 679 Joined: Sun Jun 17, 2001 4:00 pm
Post
by Warp69 » Sun Dec 19, 2004 11:37 am
Hey,
Listen to Tom
There's a relation between the ULLI setting and the 256k delay module (all devices with more than 680ms delay are using that module).
Cheers
Mehdi_T
Posts: 186 Joined: Tue Jun 08, 2004 4:00 pm
Post
by Mehdi_T » Sun Dec 19, 2004 11:43 am
exactly
Best
mehdi
fra77x
Post
by fra77x » Mon Dec 20, 2004 3:56 am
Most delays works right only at 25ms ulli...
bad thing
firubbi
Posts: 1156 Joined: Wed May 21, 2003 4:00 pm
Post
by firubbi » Mon Dec 20, 2004 4:21 am
what should be the best Ulli setting when you’re on recording? i can't set 4ms cause my processor is showing me 60/70% uses. 25ms is showing 2% cpu uses which is great but playing any a vst sampler is little unstable. What you guys do? (I’m on p4-1.4ghz and 1gb rd ram)
thanks
